12-01-2011 02:08 AM - edited 03-19-2019 04:02 AM
We have the latest Cisco Webex Connect Clients (7.1.1 Build 16597) in use in our company. With no obvious reason one of our employees now can't connect to Webex Connect getting the Error Message "An unknown error ocurred while connecting to the server." We tried to close and re open the client and to re-enter the password, both with no succes. Using another Jabber/XMPP capable IM Client works but not using Cisco Webex Connect.
Can anyone help?
Cheers,
Patrick
Solved! Go to Solution.
03-19-2014 05:52 AM
You may face this issue if your IE is working in offline mode.
To resolve:
Try going to google.com on internet explorer.
Click on connect when prompted.
Once google.com opens fine then try logging in to the WebEx Connect again.
It should work now.
10-15-2012 02:40 AM
I got the same error,can u please tell me what action i will have to take,
thanks,
Shikha
03-19-2014 05:53 AM
To resolve:
It should work now.
03-19-2014 05:52 AM
To resolve:
It should work now.
