WebRTC to CUBE(SBC) Integration
jvcumpa11
Hello everyone, has anyone successfully deployed WebRTC integration with SBC/CUBE. If so, could you please share a sample configuration and any relevant Cisco documentation links? Thank you.
collinks2
Level 5
Level 5
Hello, were you able to integrate Webrtc with CUBE? If yes, can you share the steps.
What is the use case ?
Response Signature
I want to deploy Webrtc so that users can make use of a browser and make calls to uccx agents. I have been trying to set it up using opensips as the Webrtc gateway but media is not traversing.
As a result,I started to think of CUBE to see if it can handle Webrtc calls and forward them to cucm. So the user is to make webrtc calls to cucm via CUBE
