ā12-04-2012 12:29 AM - edited ā03-19-2019 05:57 AM
Hi all,
I have a WebexNode for MCS 8.0, and need to upgrade to 8.5.
I'm trying to find where can I download the WebexNode for MCS 8.5.
Have anyone found it in the software download? I already tried to find there but no success. (
I already tried to find also in the Product Upgrade Tool, but no success.
Please help.
Antra
ā12-07-2012 04:30 PM
Hi Antra,
There are no bootable images on CCO to download, on CCO you will just find the upgrade like in this:
but if you are looking for media for 8.5 , you should be able to place a order using the PUT tool and if still issues kindly open an TAC case and someone will help you for the same.
Arun
ā12-10-2012 05:07 AM
Thanks for your help
The release date is 06-DEC-2012.
I cant' download it yet (need Additional Entitlemenent)
And I can't find also in the PUT.
so I've asked the TAC.
Hope they will help.
Antra
ā12-16-2012 01:16 AM
Do you have a WBX Node software covered with ESW contract (to use and download patch from Download Tool) or do you have UCSS active on that product (this is needed to use PUT tool). Contract number also needs to be attached to your CCO profile. If not, this often results in "Need additional entitlement" message.
