Why DBwalker says some errors on Callhandler actually it works fine
jjia
Level 2
Level 2
Unity 3.1(5) UM. Before migrating to Unity 4.0(4), we ran DBWalker3x. And found some errors on some call handlers. Although those call handlers are working normally. Please see the following example, could someone explain to me what's the reason and action should I take?
Handler Alias=3105 Media Inquiries Line
Jump to this call handler in the SA using this link: Open SA to this call handler
Text Name=3105 Media Inquiries Line
1207:(error) Voice name WAV file missing. Path referenced for file=d:\CommServer\Stream Files\3105 Media Inquiries Line_ChlName_bae5329b.wav
Extension= 3105
Handler language set to 'inherited'
Call handler associated with location object with alias=default
Call handler owner is a subscriber with an alias=ca1gcarasco
Call handler recipient is a subscriber with an alias=ca1gcarasco
After message action:
Set to go to call handler with alias=goodbyech
Schedule name=All Hours - All Days
Menu key: 1
Set to 'ignore'
Menu key: 2
Set to 'ignore'
Menu key: 3
Set to 'ignore'
Menu key: 4
Set to 'ignore'
Menu key: 5
Set to 'ignore'
Menu key: 6
Set to 'ignore'
Menu key: 7
Set to 'ignore'
Menu key: 8
Set to 'ignore'
Menu key: 9
Set to 'ignore'
Menu key: 0
Set to go to call handler with alias=ch_CA1vm2700Reception
Menu key: *
set to go to the subscriber sign in conversation
Menu key: #
set to skip greeting
Greeting rule Standard
set to take a message
Greeting rule uses greeting WAV file found at:d:\CommServer\Stream Files\3105 Media Inquiries Line _Standard_MrGreeting_f3de10bd.wav
Greeting rule Off Hours
1218:(error) greeting is set to use a missing WAV file path:d:\CommServer\Stream Files\mr_3105 Media Inquiries Line_Off Hours_11703.wav
You can automatically fix this problem by selecting the 'Remove references to missing greeting or voice name WAV files' option in the automatic repair section.
Greeting rule Alternate
Greeting rule uses greeting WAV file found at:d:\CommServer\Stream Files\3105 Media Inquiries Line _Alternate_MrGreeting_bae05907.wav
Greeting rule Busy
1218:(error) greeting is set to use a missing WAV file path:d:\CommServer\Stream Files\mr_3105 Media Inquiries Line_Busy_40834.wav
Greeting rule Internal
1218:(error) greeting is set to use a missing WAV file path:d:\CommServer\Stream Files\mr_3105 Media Inquiries Line_Internal_62662.wav
Greeting rule Error
Set to go to call handler with alias=openinggreetingch
1218:(error) greeting is set to use a missing WAV file path:d:\CommServer\Stream Files\mr_3105 Media Inquiries Line_Error_13262.wav
Contact rule Alternate switch ID= 0
Contact rule Off Hours switch ID= 0
Contact rule Standard switch ID= 0
lindborg
Looks like you've got some WAV files that went missing - if they aren't used then its not big deal - in later versions of dbWalker (for more recent versions of Unity) you can clean those up automatically.
Unity does handle a missing WAV file on the fly - so if a greeting file is missing for a greeting that gets activated, it'll switch to using the voice name of the handler or the voice name of the owner/recipient in a system constructed greeting. You may see a warning in the event log about it, though. Not the end of the world but it's worth cleaning them up.
You can do it manually by going to the handlers it flags and the greetings/voice names it notes and applying a wave file to them or setting them (in the case of a greeting) to use "system" instead of "user recorded" greetings.
Either way, it's not something that will damage your upgrade, although the invalid wave file references will all still be there after the upgrade.
