09-02-2008 05:15 AM - edited 03-18-2019 09:34 PM
I added a second language to Unity 4.2.1. There were 6 language licenses available and I only had English installed. Now, the Unity service won't start. The AvCsMgr service logs in with the Message store account. The Message store account has the Send as/receive as rights checked for denied but they are greyed out. It won't change no matter what I do. Is there something else I messed up adding the language? The Unity_<servername> has the Send as/receive as rights checked for allow in AD. The Exchange 2000 is offbox. what else can I look for? Thanks.
This is the document that I used.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_040.html#wp1104842
09-02-2008 06:45 AM
something at the app or system logs??
java
if this helps, please rate
09-03-2008 09:49 AM
Yes, I get the following sequence of errors everytime I try to start Unity.
Event Type: Error
Event Source: CiscoUnity_MALEx
Event Category: Error
Event ID: 30003
Date: 8/29/2008
Time: 4:17:42 PM
User: N/A
Computer: UNITY
Description:
An attempt to access the Primary Exchange Mailbox Store by AvCsMgr via MAPI has failed. The MAPI subsystem return the following error: You do not have permission to log on..
Event Type: Error
Event ID: 30012
Date: 8/29/2008
Time: 4:17:42 PM
User: N/A
Computer: UNITY
Description:
An occurred which prevents successful Exchange access by AvCsMgr via MAPI.
This is typically an indication of configuration issues with Unity, Exchange, or the MAPI subsystem.
Verify that the Unity services accounts are granted the correct permissions and that there are no issues with installation. The SysCheck utility may assist in diagnosing the problem.
Event Type: Error
Event Source: CiscoUnity_Doh
Event ID: 32013
Date: 8/29/2008
Time: 4:17:42 PM
User: N/A
Computer: UNITY
Description:
Doh logon failed due to messaging component logon error: 8004052eH
Event Type: Error
Event Source: CiscoUnity_Arbiter
Event Category: Init
Event ID: 1004
Date: 8/29/2008
Time: 4:17:42 PM
User: N/A
Computer: UNITY
Description:
Unable to log onto the Doh. Use SysCheck to verify that the account AvCsMgr is running under has the correct permissions.
Event Type: Error
Event Source: CiscoUnity_CsServices
Event ID: 1021
Date: 8/29/2008
Time: 4:17:42 PM
User: N/A
Computer: UNITY
Description:
AvCsMgr: Component Arbiter initialize failed. Turn on diagnostics for component Arbiter to troubleshoot. Technical Details: IAvCsComponent::Initialize failed with error [0x80004005; E_FAIL]
Event Type: Error
Event ID: 1009
Date: 8/29/2008
Time: 4:17:42 PM
User: N/A
Computer: UNITY
Description:
AvCsMgr service failed to initialize the component manager.
09-03-2008 10:55 AM
i'd rerun the PW, run MSCW and also delete the MAPI profile
java
09-03-2008 11:27 AM
I ran the Permissions Wizard and deleted the MAPI profile and ran the Message Store Confiuration Wizard. But, it still has a red X.
The Message Store service MsgStorescv has the Send as/Receive as rights checked for deny but they are greyed out so I can't change them. It appears to be something with the Global Catalog or the Mapi profile. Any other things to look at?
09-03-2008 11:48 AM
Could you please send me the app and sys log from the server? Let me know ask you this, is message store account member of domain admins group? Do you see DOH failure errors in the app log? My email is shabbir@tapal.net
09-03-2008 12:31 PM
I'll send you the files. The message store account is a member of the Domain Admins group. There are DOH errors in the logs.
