Wrong language with remote notification - Unity Connection 7.1
scondo
I have two language in the Unity Connection, and when we activate the remote notification on a cellular, the system talk to the user in the System default language, in my case is in French.
So even if the mailbox of the user is set in english, Unity connection play the notification message in French.
Is this normal?
Thank you.
Sonia Condo
Bell Canada
Application design specialist
Craig Cooper
Hi Sonia,
Which build of Cisco Unity Connection (CUC) 7.1 is being used?   There have been issues, such as CSCta66948, "Msg Notification outdial uses system default language", that are resolved in later builds or versions (CSCta66948, in particular, is resolved in CUC 8.0).
Kind regards,
Craig
