AT&T Connection Issue
Hi experts,
The company I work for is mexican. One of our customers has a branch in Miami and they have an AT&T SIP Trunk,  the issue is that they can`t complete calls to Toll Free Numbers, I have called AT&T service and they said the problem is ours.
If I run a SIP debug in the gateway I receive the 403 SIP code forbidden just for Toll Free Numbers.
The gateway configuration is below.
service timestamps log datetime localtime show-timezone
boot-start-marker
boot-end-marker
logging buffered 51200 informational
no aaa new-model
clock timezone MIAMI -5 0
clock summer-time MIAMI recurring 2 Sun Mar 0:00 1 Sun Nov 0:00
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
address-hiding
mode border-element
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  session refresh
  header-passing
  error-passthru
  registrar server expires max 3600 min 120
  asserted-id pai
  privacy pstn
  no update-callerid
  early-offer forced
  midcall-signaling passthru
  privacy-policy passthru
  g729 annexb-all
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class codec 2
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
codec preference 4 g711alaw
voice class codec 10
codec preference 1 g729r8 bytes 30
codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 5
voice class sip-profiles 1
request INVITE sdp-header Audio-Attribute modify "a=ptime:20" "a=ptime:30"
response ANY sdp-header Audio-Attribute modify "a=ptime:20" "a=ptime:30"
request REINVITE sdp-header Attribute modify "a=T38FaxFillBitRemoval:0" ""
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice class sip-profiles 2
response ANY sip-header Allow-Header modify "UPDATE," ""
license accept end user agreement
license boot module c2900 technology-package uck9
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
interface Embedded-Service-Engine0/0
no ip address
description To SIP PSTN
ip address 12.161.41.162 255.255.255.224
duplex auto
speed auto
interface Vlan1
no ip address
ip route 12.0.0.0 255.0.0.0 GigabitEthernet0/0
ip route 12.194.0.0 255.255.0.0 12.161.41.161
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 130.61.1.3 identifier 1 priority 1 version 7.0
sccp ccm 130.61.1.4 identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 222 register ConfMIA
associate profile 111 register XcodeMIA
associate profile 333 register MTPMIAMI
dspfarm profile 111 transcode
description DSP Resources Transcoding
codec g729br8
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 9
associate application SCCP
dspfarm profile 222 conference
description DSP Resources Conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 11
dspfarm profile 333 mtp
codec g711ulaw
maximum sessions hardware 1
maximum sessions software 4000
dial-peer voice 1000 voip
description llamadas locales Miami
preference 1
destination-pattern 3[0-9]........
session protocol sipv2
session target ipv4:12.194.99.53
voice-class codec 1
voice-class sip asserted-id pai
voice-class sip privacy-policy passthru
voice-class sip early-offer forced
voice-class sip profiles 1
dtmf-relay rtp-nte cisco-rtp
ip qos dscp 5 media
no vad
dial-peer voice 5000 voip
description Toll Free Numbers
destination-pattern 18……...
voice-class codec 1
ip qos dscp 5 media
no vad
sip-ua
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers trying 1000
timers connect 100
timers register 250
sip-server ipv4:12.194.99.53:5060
host-registrar
g729-annexb override
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 130.90.3.10 port 2000
max-ephones 58
max-dn 50
system message primary Altex USA Survivable Telephony
system message secondary AltexUSA Survivable
transfer-pattern 2..
transfer-pattern 3..
transfer-pattern 4..
keepalive 60
voicemail 6670
call-forward pattern #
call-forward pattern .T
call-forward busy 6671
call-forward noan 6670 timeout 16
moh GrupoAltexespanolOK.au
multicast moh 239.1.1.1 port 16384
time-zone 9
date-format dd-mm-yy
line con 0
exec-timeout 0 0
logging synchronous
login local
stopbits 1
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
logging synchronous
login local
transport input all
scheduler allocate 20000 1000
ntp server 130.61.1.10 prefer
end
Pleas Help me!!
Best Regards!
George Paxson
We are on At&t as well.  At&t would not accept calls to 800 numbers with a calling party set to a number that is not a DID on their service.  I had to port our main number from TW to At&t before they allowed the calls to 800 numbers.
George Paxson
Hi George,
I configured my ANY ( at&t Main number) and now everithing goes well.
