Cisco Unity Connection - Voicemail - Recall voicemessage sender
hi,
i have Cisco Unity Connection.
After i listen a messagge in my voicemail,is there a fast way to recall the voicemessage sender.
i'd like to have the option after message that permit me to recall who has left the voicemessage.
thanks
Jaime Valencia
Yes, you can enable reply to the messages by calling them, that's under the COS and the restriction tables would need to allow such calls, as well as your call control recognize the numbers to which you want to call in the format in which they're dialed by CUC.
java
if this helps, please rate
