CUCM and Unity Licensing help
vrostowsky
Level 5
Level 5
I am renewing the Smartnet for my company but when i looked at my quote from my vendor, it raised a few flags.  To me it looks as though they are quoting both old SKU's and the new replacement SKU's for my licensing.  My question is which licensing should I use if I am planning on upgrading my CUCM and Unity to 10.5 (I know the license model changes to UWL).  I opened a ticket with licensing but was informed that they were not the best resource to answer this question.
Item Name                                           Quantity
UCM-9X-ENH-UCL                                   xx
UCM-9X-VM-UCL                                     xx
UCM-9X-ESS-UCL                                    xx
UCM-9X-BAS-UCL                                    xx
UCM-9X-UCL-ENH                                    xx
UCM-9X-UCL-ESS                                    xx
UCM-9X-UCL-VM                                     xx
UCM-9X-UCL-BAS                                    xx
Thanks in advance-
Vince
MarcusPresidio
Level 4
Level 4
If you are renewing this is normal because you are purchasing support for the version you are currently on.
It would show 10.x or 11.x etc  if you upgraded using the PUT tool.
MarcusPresidio
Level 4
Level 4
Marcus-
If this is normal, then I appreciate your quick response.  I just wanted to make sure I had the right support in the quote.
Thanks-
Vince
