CUE pin reset without using GUI
MooneyN
I need to reset CUE user PIN's however i can't use the HTTP GUI - i can only use CLI. This is due to a firewall block.
Is there a way to change/reset the PIN with the CLI? I know i can unlock the accounts but the accounts are not locked, user has just forgotten PIN.
Markus Schneider
Sure. From the CLI (in command mode, not config mode):
cue# user xyz pin 123
Markus Schneider
so simple and yet so helpful, thanks a lot!!
