CUMA 7.1.3 and Blackberry Bold 9000
bluejays
I am working on a project where I need to deploy CUMA 7.1.3 and integrate that with Blackberry devices. According to Release Note of Blackberry Client 3.1.12, Blackberry Bold 9000 is a supported model. However, I am not able to select that from the handset platform management page.
Can someone please confirm if Blackberry Bold is supported?
Jaime Valencia
I just looked and it's supported, you should be able to choose any model and should work fine on the 9000 model.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Indeed, I too have found this to be the case.
Mark
I uploaded the client 3.1.12 to BES(4.1.6) and the BES said (under the Software deployment policy) the device is not supported. And I don't have the client icon on the phone.
I will wait for another couple hours to see if the BES pushes the client.
