02-24-2010 03:52 AM - last edited on 03-25-2019 09:34 PM by ciscomoderator
Hi all,
I downloaded the beta-trial kit for CUCM 8.0 and tried to perform an upgrade on our lab machine. After about 20-30 minutes after starting the installation we get "An unknown error occurred while accessing the upgrade file" error message and the upgrade stops.
Any idea about how to fix this and perform the upgrade?
Thank you,
Raluca Butnaru
02-24-2010 04:29 AM
The Version 8 beta is new install only as far as I am aware. You will also get a problem with the license from 7.
02-24-2010 04:41 AM
When I downloaded from Cisco site ISO files, there was ISO(part1+part2) separatelly for fresh and upgrade.
05-30-2011 09:33 AM
Did you resolve this problem? Do you have the solution?
