Integration of Unity Connection 8.6 with Avaya CM 6.2
karlareyes
We would like to integrate Unity Connection 8.6 with Avaya Aura CM 6.2,   I am trying to find information on the integration and what hardware is required to do the integration, only found about PIMG on older Avaya systems.  Is it necessary to do the PIMG integration with Avaya CM6 and Unity Connection 8.X voicemail system?   Any limitations?
Thanks in advance!
ndehmer
Level 4
Level 4
We are currently running the TIMG's hardwired to the Avaya system and then SIP to CUC.  However we have looked at, and will be again shortly, looking at going SIP end to end.  From my understanding, you need something in between to do SIP header normalization.  We have more than likely will be using a CUCM SME cluster to do the normalization.  I believe Cisco provides a guide on the setup on their side, don't know if Avaya does on their side.
