No Ringback for Calls transfered from Unity Connecion ( AA) Call Handler
mohamedbineesh
When People from PSTN Calls ,  they hear  IVR from AA configured in Unity Connection via a CTI Route Point.
AA - IVR asks to dial any Internal Extension . Then Calls are transfered to that particular Extention and it rings
and calls get connected.
PROBLEM : The Person on the PSTN side do not hear Ringback or MoH while AA transfers Call to Extensions.
Anyways, Everything is working fine internaly. Problem exist only when call is from outside , PSTN.
Here is the Call Flow >
PSTN------- > SIP Service Provider------> CUBE -----sip---- > CUCM ----SCCP-- > Unity Conx (AA) -----> transfer to Internal Extension(SCCP Phone)
Message was edited by: Mohammed Bineesh E.K.
giorgiosalsiri
Hi Mohammed,
Can you give the output of the CUBE SIP Dial Peer and explain how the SIP trunk is configured on CUCM?
What version of CUCM are you running?
Is this a new implementation?
Was it ever working or did it just start happening?
What codecs are you using?
Do you have MTP checked on your SIP trunk?  I have seen similar problems requiring MTP on the CUCM SIP Trunk.  I would suggest to configure a software MTP on the CUBE.
GS
Thanks for your response.
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
dial-peer voice 1 voip
description ## Incoming SIP Calls ##
translation-profile incoming STRIP012
rtp payload-type cisco-codec-fax-ack 105
rtp payload-type cisco-codec-fax-ind 106
rtp payload-type nte 97
session protocol sipv2
incoming called-number 0127599[123]..
codec g711ulaw
no vad
dial-peer voice 2 voip
description ## To CUCM SUB ##
destination-pattern 7599[123]..
session target ipv4:10.1.21.30
voice-class codec 1
dtmf-relay rtp-nte
no vad
------Iam Running CUCM 8.6.2
------ Yes this is a new Implementation.
---- New Impelementation. Was no woriking
----g711alaw on service provider side.
----g711ulaw on cube,cucm side.
----Is already Checked.
I already have IOS Software MTP running on CUBE and its added in SIP TRUNK MRGL.
STILL ITS THE SAME
Since there is no Ringback heard on the pstn end . Have you verified if there is an annuciator present in MRGL of the sip trunk pointing to the cube .  Could you add this to the MRGL of the sip trunk if not already present?
Karthik Sivaram
