Scale Unity Connection users beyond 20000
yadwindersingh
Hi all,
Can anyone help me to find below answeres?
1. Number of server in 1 unity cluster?
2.Number of users supported by 1 unity server and 1 unity cluster?
3. How can i scale number of users beyond 20,000?
4. What i have to do to scale users beyond 1,00,000?
5. What will happen if unity publisher down?
6.What we can do if unity publisher goes down and needs to setup new publisher?
2 Accepted Solutions
Terry Cheema
1) Two unity connection servers are supported in a cluster
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/design/guide/10xcucdgx/10xcucdg060.html#pgfId-1052981
2) Depends on the specs upto 20,000 for both
Refer to above design guide and also the spec sheet here: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/supported_platforms/10xcucspl.html#pgfId-703559
3) Join Multiple clusters
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/design/guide/10xcucdgx/10xcucdg030.html#pgfId-1062645
4) As mentioned in Point 3 you can join upto 10 unity Connection clusters
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/design/guide/10xcucdgx/10xcucdg030.html#pgfId-1062645
5) Sub will service voicemail, for more details refer to below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/install_upgrade/guide/10xcuciumgx/10xcuciumg040.html#pgfId-748021
6) You can re-install the pub following std procedures.
If you have more queries refer to the Unity Connection Design Guide: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/design/guide/10xcucdgx.html
-Terry
Please rate all helpful posts
Hi Yadwinder - Not a problem. When new Pub is built you dont have to build the entire cluster. You build the pub server as per any new installation and then restore it from DRS backups.
Here is a reference to the DRS guide: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/drs/10_0_1/CUCM_BK_D220A91D_00_disaster-recovery-system-cucm-100/CUCM_BK_D220A91D_00_disaster-recovery-system-cucm-100_chapter_011.html
If you find the posts helpful please do rate all helpful content and also mark the thread as answered if you have no other queries. This helps flag the content which can be useful to other users and is generally encouraging and also is a good etiquette.
Please feel free to ask if you have more questions.
-Terry
5 Replies 5
Terry Cheema
-Terry
HiTerry,
Thanks for your help.
This is about step6:
So when we setup new publisher whether we need to setup new subscriber also or only publisher can work with existing subscriber in same cluster?
-Terry
Hi Terry,
Thanks for your answeres, Now the last one....
Can we use the same steps to built  new CUCM publisher from scrap ? Do we need to install whole cluster or just Publisher ?
Hi Mate,
Yes the procedure is pretty much similar. Here is the DRS guide for unity connection: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/install_upgrade/guide/10xcuciumgx/10xcuciumg020.html#pgfId-1174127
The previous link I referenced was for CUCM actually.
However there is one difference: When configuring backups for CUCM Cluster you configure Disaster Recovery System Backups from Publisher only and you can use that file to restore both the Pub and Sub. So you have one backup file which can restore publisher server as well as Subscriber server as well.
But with Connection Cluster: You have to configure the backups on both Pub and Sub. If you are rebuilding/restoring the Pub you need to use the Pub backups and in case you are restoring/rebuilding a sub server you need to use the backup file for the Sub.
Apart from that for both applications you just need to rebuild the server that has gone bad and not the entire cluster.
-Terry
