Muhammad Afzal
Overview
In today’s fast paced digitization, Kubernetes enables enterprises to rapidly deploy new updates and features at scale while maintaining environmental consistency across test/dev/prod. Kubernetes lays the foundation for cloud-native apps which can be packaged in container images and can be ported to diverse platforms. Containers with micro-service architecture, managed and orchestrated by Kubernetes, help organizations embark on a modern development pattern. Moreover, Kubernetes has become a de facto standard for container orchestration and offers the core for on-premise container cloud for enterprises. it's a single cloud-agnostic infrastructure with a rich open source ecosystem. It allocates, isolates, and manages resources across many tenants at scale as needed in elastic fashion, thereby, giving efficient infrastructure resource utilization.
OpenShift Container Platform (OCP) with its core foundation in Kubernetes is a platform for developing and running containerized applications. It is designed to allow applications and the data centers that support them to expand from just a few machines and applications to thousands of machines that serve millions of clients. OCP helps organizations use the cloud delivery model and simplify continuous delivery of applications and services on OCP, the cloud-native way.
In this document, I’ll be outlining step by steps guide how to deploy OCP on Cisco UCS servers. In the reference topology, I started the deployment with 3 x controllers and 1 x worker node on Cisco UCS C240 M5 Servers connected with Cisco UCS Fabric interconnect 6332. I added the worker node after installing the controllers which is running Red Hat Enterprise Linux whereas controllers are running Red Hat CoreOS. By following the same steps, many worker nodes can be added as you scale the environment.
Deployment
Logical Topology
Figure 1 shows the logical topology of this reference design.
Figure 1: Logical Topology
Software Versions
Software
Version
Red Hat OpenShift
4.5
Red Hat CoreOS
4.5.2
7.8
Ansible
2.9.10
OpenShift Installation Program on Linux
4.5.2
OpenShift CLI on Linux
4.5.2
Kubernetes
1.16 with CRI-O runtime
Prerequisites
  1. Configure DHCP or set static IP addresses on each node. This document sets static IP addresses to the nodes.
  2. Provision the required load balancers.
  3. DNS is absolute MUST. Without proper DNS configuration, installation will not continue.
  4. Ensure network connectivity among nodes, DNS, DHCP (if used), HAProxy, Installer or Bastion node.
  5. Red Hat Subscription with access to OpenShift repositories.
Note: It is recommended to use the DHCP server to manage the machines for the cluster long-term. Ensure that the DHCP server is configured to provide persistent IP addresses and host names to the cluster machines.
Minimum Required Machines
The smallest OpenShift Container Platform clusters require the following hosts:
  1. 1 x temporary bootstrap machine
  2. 3 x Control plane, or master machines
  3. 2+  compute machines, which are also known as worker machines (Minimum 2+ worker nodes are recommended. However, in this reference design, I setup 1 x RHEL worker or compute node for the sake of simplicity. Another node can be added by repeating the same procedure as outlined in this document)
Note: The cluster requires the bootstrap machine to deploy the OCP cluster on the three control plane machines. Bootstrap machine can be removed later, after the install is completed.
Note: For control plane high availability, it is recommended to use separate physical machine.
Note: Bootstrap and control plane must use Red Hat Enterprise Linux CoreOS (RHCOS) as the operating system. For compute or worker node RHCOS or RHEL can be used.
Lab Setup
Server
IP
Specs
OS
Role
Lab Jump Host
10.16.1.6
Public IP
Virtual Machine
Windows Sever
DNS, NAT (DNS server and Default Gateway for all the nodes)
rhel1.hdp3.cisco.com
10.16.1.31
Cisco UCS C240 M5
RHEL 7.6
RHEL install host also termed as “Bastion” node.
OpenShift installation program, oc client, HAproxy, Webserver (httpd), Ansible, OpenShift Ansible Playbook
bootstrap.ocp4.sjc02.lab.cisco.com
10.16.1.160
Cisco UCS C240 M5
CoreOS 4.5.2
Bootstrap node (temporary)
master0.ocp4.sjc02.lab.cisco.com
10.16.1.161
Cisco UCS C240 M5
CoreOS 4.5.2
OpenShift control plane master node + worker node
master1.ocp4.sjc02.lab.cisco.com
10.16.1.162
Cisco UCS C240 M5
CoreOS 4.5.2
master2.ocp4.sjc02.lab.cisco.com
10.16.1.163
Cisco UCS C240 M5
CoreOS 4.5.2
worker0.ocp4.sjc02.lab.cisco.com
10.16.1.164
Cisco UCS C240 M5
RHEL 7.8
OpenShift Worker or compute node
Reference Physical Topology
Below Figure shows the reference design physical setup
Note:Bootstrap node is temporary and will be removed once the installation is completed.
  1. For simplicity, single vNIC is configured in each node in Cisco UCS Manager. In large scale design, multiple vNICs is recommended to separate different kinds of traffic such as control traffic and OpenShift SDN traffic.
  2. vNIC high-availability is maintained at Cisco UCS Fabric Interconnect level by mapping vNIC to Fabric-A and failover to Fabric-B
  3. This solution does not implement Linux bonding with multiple active vNIC. However, installation of CoreOS does offer bond configuration at the time of first boot.
  4. Bootstrap node is only used during the install time. its main purpose is to run bootkube. bootkube technically provides a temporary single node master k8 for bootstraping. After installation, this node can be repurposed.
  5. Master nodes will provide the control plane services to the cluster. it runs API server, scheduler, controller manager, etcd, coredns, and more. Three master nodes are required front-end by the load balancer. Master nodes runs control plane services inside containers. Masters can also be schedulable for PODs and containers.
  6. Workloads runs on compute nodes. Infrastructure can be scaled by adding more compute nodes when additional resources are needed. Compute nodes can have specialized hardware such as NVMe, SSDs, GPU, FPGA, and etc.
High level install check list
There are two approaches for OCP deployment.
  1. Installer Provisioned Infrastructure (IPI)
  2. User Provisioned Infrastructure (UPI)
To learn more about these installation types, please refer to Red Hat documentation.
This OCP deployment is based on UPI.
UPI based install involved the following high-level steps:
  1. Acquisition of appropriate hardware
  2. Configure DNS
  3. Configure Load Balancer
  4. Setup non-cluster host to run a web server reachable by all nodes.
  5. Setup OCP installer program
  6. Setup DHCP (Optional if using static IP)
  7. Create install-config.yaml as per your environment.
  8. Use the openshift-install command to generate the RHEL CoreOS ignition manifests, host these files via the web server.
  9. PXE or ISO boot the cluster members to start the RHEL CoreOS and OpenShift install
  10. Monitor install progress with the openshift-install command
  11. Validate install using OpenShift client tool or launch the web console.
Setup DNS
In this deployment, I utilized DNS Manger to configure DNS records in Windows Server. However, Linux server can also be configured for DNS.
Note: It is important to pay special attention to DNS record. Most unsuccessful install issues arise from incorrect DNS entries
Component
DNS A/AAA Record
IP (For Reference Only)
Description
Kubernetes API
api.ocp4.sjc02.lab.cisco.com
10.16.1.31
IP address of the load balancer.
api-int.ocp4.sjc02.lab.cisco.com
10.16.1.31
Bootstrap
10.16.1.160
IP address for bootstrap node
Master<index>
10.16.1.161
IP address of nodes dedicated for master’s role in OpenShift cluster
10.16.1.162
10.16.1.163
Worker<index>
10.16.1.164
IP address of worker node. For each worker node, add A/AAA DNS record.
Etcd-<index>
etcd-0.ocp4.sjc02.lab.cisco.com
10.16.1.161
Each etcd instance to point to the control plane machines that host the instances. Etcd will be running in respective master nodes
etcd-1.ocp4.sjc02.lab.cisco.com
10.16.1.162
etcd-2.ocp4.sjc02.lab.cisco.com
10.16.1.163
_etcd-server-ssl._tcp.ocp4.sjc02.lab.cisco.com
For each control plane machine, OpenShift Container Platform also requires an SRV DNS record for etcd server on that machine with priority 0, weight 10 and port 2380. A cluster that uses three control plane machines requires the following records:
Routes
*.apps.ocp4.sjc02.lab.cisco.com
10.16.1.31
IP address of load balancer
DNS AAA Record
Etcd SRV Record
Routes DNS Record
Setup Load Balancer
Load balancer is required for Kubernetes API server, both internal and external as well as for OpenShift router.
In this deployment, for simplicity we used HAProxy to be installed and configured in Linux server. However, existing load balancer can also be configured as long as it can reach to all OpenShift nodes. This document does not make any official recommendation for any specific load balancer.
In this reference design, we installed HA proxy in rhel1 server by running the following command.
[root@rhel1 ~]# yum install haproxy
After the install configure /etc/haproxy/haproxy.cfg file. We need to configure port 6443 and 22623 to point to bootstrap and master nodes. We also need to configure port 80 and 443 to point to the worker nodes. Below is the example of HAproxy config used in this reference design.
[root@rhel1 ~]# vi /etc/haproxy/haproxy.cfg
# Example configuration for a possible web application.  See the
# full configuration options online.
#   http://haproxy.1wt.eu/download/1.4/doc/configuration.txt
# Global settings
global
    # to have these messages end up in /var/log/haproxy.log you will
    # need to:
    # 1) configure syslog to accept network log events.  This is done
    #    by adding the '-r' option to the SYSLOGD_OPTIONS in
    #    /etc/sysconfig/syslog
    # 2) configure local2 events to go to the /var/log/haproxy.log
    #   file. A line like the following can be added to
    #    local2.*                       /var/log/haproxy.log
    log         127.0.0.1 local2
    chroot      /var/lib/haproxy
    pidfile     /var/run/haproxy.pid
    maxconn     4000
    user        haproxy
    group       haproxy
    daemon
    # turn on stats unix socket
    stats socket /var/lib/haproxy/stats
# common defaults that all the 'listen' and 'backend' sections will
# use if not designated in their block
defaults
    mode                    http
    log                     global
    option                  httplog
    option                  dontlognull
    option http-server-close
    #option forwardfor       except 127.0.0.0/8
    option                  redispatch
    retries                 3
    timeout http-request    10s
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout server          1m
    timeout http-keep-alive 10s
    timeout check           10s
    maxconn                 3000
frontend openshift-api-server
    bind *:6443
    default_backend openshift-api-server
    mode tcp
    option tcplog
    balance source
    mode tcp
    # comment out or delete bootstrap entry after the successful install and restart haproxy
    server bootstrap.ocp4.sjc02.lab.cisco.com 10.16.1.160:6443 check
    server master0.ocp4.sjc02.lab.cisco.com 10.16.1.161:6443 check
    server master1.ocp4.sjc02.lab.cisco.com 10.16.1.162:6443 check
    server master2.ocp4.sjc02.lab.cisco.com 10.16.1.163:6443 check
frontend machine-config-server
    bind *:22623
    default_backend machine-config-server
    mode tcp
    option tcplog
    balance source
    mode tcp
    server bootstrap.ocp4.sjc02.lab.cisco.com 10.16.1.160:22623 check
    server master0.ocp4.sjc02.lab.cisco.com 10.16.1.161:22623 check
    server master1.ocp4.sjc02.lab.cisco.com 10.16.1.162:22623 check
    server master2.ocp4.sjc02.lab.cisco.com 10.16.1.163:22623 check
frontend ingress-http
    bind *:80
    default_backend ingress-http
    mode tcp
    option tcplog
    balance source
    mode tcp
    server worker0.ocp4.sjc02.lab.cisco.com 10.16.1.164:80 check
# Specify master nodes as they are also acting as worker node in this setup
# Master node entries are not required if masters are not acting as worker node as well.
server master0.ocp4.sjc02.lab.cisco.com 10.16.1.161:80 check
server master1.ocp4.sjc02.lab.cisco.com 10.16.1.162:80 check
server master2.ocp4.sjc02.lab.cisco.com 10.16.1.163:80 check frontend ingress-https bind *:443 default_backend ingress-https mode tcp option tcplog backend ingress-https balance source mode tcp server worker0.ocp4.sjc02.lab.cisco.com 10.16.1.164:443 check # Specify master nodes as they are also acting as worker node in this setup server master0.ocp4.sjc02.lab.cisco.com 10.16.1.161:443 check server master1.ocp4.sjc02.lab.cisco.com 10.16.1.162:443 check server master2.ocp4.sjc02.lab.cisco.com 10.16.1.163:443 check
Restart HAProxy service and verify that it is running without any issues.
[root@rhel1 ~]# systemctl restart haproxy
[root@rhel1 ~]# systemctl status haproxy
Covering line by line details of haproxy.cfg file is beyond the scope of this document, please refer to haproxy documentations available online for details. Make sure all the ports specified in haproxy are opened in the server where it is running.
Setup Webserver
A webserver is also required to be setup for placing ignition configurations and installation images for Red Hat CoreOS. Webserver must be reached by bootstrap, master, and worker nodes during the install. In this design, we setup Apache web server (httpd).
If webserver is not already installed. Run the following command in installer server.
[root@rhel1 ~]# yum install httpd
Create a folder for ignition files and CoreOS image.
[root@rhel1 ~]# mkdir -p /var/www/html/ignition-install
Download Red Hat CoreOS image to this folder
[root@rhel1 ~] cd /var/www/html/ignition-install
[root@rhel1 ignition-install]# curl -J -L -O https://mirror.openshift.com/pub/openshift-v4/x86_64/dependencies/rhcos/4.5/latest/rhcos-4.5.2-x86_64-metal.x86_64.raw.gzRHCOS Raw image downlaod.png
Setup DHCP (Optional)
DHCP is recommended for high scale production grade deployment to provide persistent IP addresses and host names to all the cluster nodes. Use IP reservation so that IP should not change during node reboots.
However, for simplicity I used static IP addresses in this deployment for all the nodes.
Installation
This installation is comprised of 3 x master nodes, 1 x worker nodes, and 1 x bootstrap node. Install will be performed from Linux host which we also call as “Bastion” node. This is installed will be using static IP.
Create install folder in bastion node as follows:
# mkdir ocp-install
# cd ocp-install
Generate SSH private key and add it to the agent
Create an SSH private key which will be used to SSH into master and bootstrap nodes as the user core. The key is added to the core users’ ~/.ssh/authorized_keys list via the ignition files.
# ssh-keygen -t rsa -b 4096 -N '' -f installer
Verify if ssh-agent is running or otherwise start the ssh-agent as a background task
# eval "$(ssh-agent -s)"
Add the SSH private key to the ssh-agent
[root@linuxjh ocp-install]# ssh-add installer
Obtain Installation Program
Before you begin installation for OpenShift Container Platform, it is important to download OpenShift installer and set it up in bastion host.
# curl -J -L -O https://mirror.openshift.com/pub/openshift-v4/clients/ocp/4.5.2/openshift-install-linux-4.5.2.tar.gz
# tar -zxvf openshift-install-linux-4.5.2.tar.gz
# chmod 777 openshift-install
OpenShift installer can also be obtained from the following URL. This requires Red Hat login registered with Red Hat customer portal.
https://cloud.redhat.com/openshift/install/metal/user-provisioned
At this time, OpenShift installer is available for Mac and Linux OS.
Download Command Line Interface (CLI) Tool
You can install the OpenShift CLI(oc) binary on Linux by using the following procedure.
[root@rhel1 ocp-install]# curl -J -L -O https://mirror.openshift.com/pub/openshift-v4/clients/ocp/4.5.2/openshift-client-linux-4.5.2.tar.gz
Unpack the archive
[root@rhel1 ocp-install]# tar -zxvf openshift-client-linux-4.5.2.tar.gz
Place the oc binary in a directory that is on your PATH
# echo $PATH
# export PATH=$PATH:/root/ocp-install/
CLI can also be downloaded from
OpenShift command line interface is available for Linux, MacOS, and Windows at the time of this writing.
Download pull secret
Installation program requires pull secret. This pull secret allows you to authenticate with the services that are provided by the included authorities, including Quay.io, which serves the container images for OpenShift Container Platform components.
Without pull secret, installation will not continue. It will be specified in install config file in the later section of this document.
From the OpenShift Cluster Manger site (https://cloud.redhat.com/openshift/install/metal/user-provisioned), pull secret can either be downloaded as .txt file or copied directly in the clipboard.
Get the pull secret and save it in pullsecret.txt file
# cat pullsecret.txt
Create install configuration
Run the following command to create the install-config.yaml file
# cat <<EOF > install-config.yaml
apiVersion: v1
baseDomain: sjc02.lab.cisco.com
compute:
- hyperthreading: Enabled
  replicas: 0
controlPlane:
  replicas: 3
metadata:
networking:
  clusterNetworks:
  - cidr: 10.254.0.0/16
    hostPrefix: 24
  networkType: OpenShiftSDN
  serviceNetwork:
  - 172.30.0.0/16
platform:
  none: {}
pullSecret: '$(< /root/ocp-install/pullsecret.txt)'
sshKey: '$(< /root/ocp-install/installer.pub)'
EOF
Note: Make a backup of install-config.yaml - as this file is deleted once the ignition-config are created. Or it can be recreated by running the above command.
Please note/change the following according to your environment:
  • baseDomain – This is the domain in your environment. For example, I configure ocp4.sjc02.lab.cisco.com as the base domain earlier in the steps.
  • metadata.name – This would be clusterId.
            Note: This will effectively make all FQDNS ocp4.sjco2.lab.cisco.com
              - Login with your Red Hat account
              - Click on "Bare Metal"
              - Either "Download Pull Secret" or "Copy Pull Secret"
  • sshKey - This is your public SSH key (e.g. id_rsa.pub) - # cat ~/.ssh/id_rsa.pub
Generate Ignition Configuration Files
Ignition is a tool for manipulating configuration during early boot, before the operating system starts. This includes things like writing files (regular files, systemd units, networkd units, etc.) and configuring users. Think of it as a cloud-init that runs once (during first boot).
OpenShift 4 installer generates these ignition configs to prepare the node as an OpenShift either bootstrap, master, or worker node. From within your working directory (in this example it's ~/ocp-install) generate the ignition configs.
[root@linuxjh ocp-install]# ./openshift-install create ignition-configs --dir=/root/ocp-install
Note: Make sure install-config.yaml file should be in the working director such as /root/ocp-install directory in this case.
Note: Creating ignition config will result in the removal of install-config.yaml file. Make a backup of install-config.yaml before creating ignition configs. You may have to recreate the new one if you need to re-create the ignition config files
This will create the following files.
├── auth
│   ├── kubeadmin-password
│   └── kubeconfig
├── bootstrap.ign
├── master.ign
├── metadata.json
└── worker.ign
The list of the install folder is shown in the below figure.
Copy the .ign file to your webserver
# cp *.ign /var/www/html/ignition-install/
Give appropriate permissions, otherwise, it will not work
# chmod o+r /var/www/html/ignition-install/*.ign
Before we begin installing RHCOS in bootstrap and master nodes, make sure you have the following files available in your webserver as show in below figure.
Download RHCOS iso
Download the RHCOS 4.5.2 iso from the following link.
https://mirror.openshift.com/pub/openshift-v4/x86_64/dependencies/rhcos/4.5/latest/rhcos-4.5.2-x86_64-installer.x86_64.iso
Install RHCOS
Use the ISO to start the RHCOS installation. PXE can also be setup for RHCOS installs, however, it is not covered in this document and beyond the scope of this writing.
Activate virtual media in Cisco UCS Manager and map this iso as shown in Figure in Cisco UCSM KVM
Power cycle the server from UCSM
After the instance boots, press the “TAB” or “E” key to edit the kernel command line.
Add the following parameters to the kernel command line:
coreos.inst=yes
coreos.inst.install_dev=sda
coreos.inst.image_url=http://10.16.1.31/ignition-install/rhcos-4.5.2-x86_64-metal.x86_64.raw.gz
coreos.inst.ignition_url=http://10.16.1.31/ignition-install/bootstrap.ign
ip=10.16.1.160::10.16.1.6:255.255.255.0:bootstrap.ocp4.sjc02.lab.cisco.com:enp63s0:none nameserver=10.16.1.6 nameserver=8.8.8.8
bond=<bonded_interface> if any
NOTE: Make sure above parameters should be supplied in one line (means no enter key). it is written above with enter key or new line for readability purposes.
Syntax for the static ip is: ip=$IPADDR::$DEFAULTGW:$NETMASK:$HOSTNAME:$INTERFACE:none:$DNS or for DHCP it is: ip=dhcp
If you are providing DNS name for image_url and ignition_url, make sure when coreos iso boots up , it should be able to resolve it. Means your DHCP set the nameserver you are using or instead specify as static
In Cisco UCS KVM, you can also paste it from the clipboard. From KVM window, click File-->Paste Text From Clipboard
In case, if the RHCOS install did not go through as a result of typo or providing incorrect values for parameters. You can perform the following as shown in figure once the system boots up with iso.
You can run coreos-installer in /usr/libexec folder as below
/usr/libexec/coreos-installer -d sdi -b http://10.16.1.31/ignition-install/rhcos-4.5.2-x86_64-metal.x86_64.raw.gz -i http://10.16.1.31/ignition-install/master.ign
Unmap the media mount in UCSM KVM
Reboot the bootstrap after install
After the reboot, to ssh bootstrap
# ssh core@bootstrap.ocp4.sjc02.lab.cisco.com
Monitor the install
Once the bootstrap server is up and running, the install is actually already in progress. First the masters "check in" to the bootstrap server for its configuration. After the masters are done being configured, the bootstrap server "hands off" responsibility to the masters. You can track the bootstrap process with the following command.
./openshift-install wait-for bootstrap-complete --log-level debug
You can monitor the detailed installation progress by SSH to bootstrap node and run the following
# journalctl -b -f -u release-image.service -u bootkube.service
Install RHCOS in Master Nodes
Repeat the same steps as outlined to install the RHCOS iso in bootstrap node. For master, specify masters ip and  FQDN and master.ign ignition config file as shown for example.
Reboot server for ignition to be loaded.
Install RHCOS in Worker Nodes
In this setup, I'll be deploying RHEL in the worker node which will be covered in the subsequent section of this document. If you decide to deploy RHCOS in the worker node, follow the steps as outlined for installing the bootstrap node. Make sure to specify worker.ign ignition file in coreos.inst.ignition_url parameter. For example, coreos.inst.ignition_url=http://10.16.1.31/ignition-install/worker.ign
As for example, apply the following as configuration parameters after pressing the Tab key
coreos.inst=yes
ip=10.16.1.165::10.16.1.6:255.255.255.0:worker1.ocp4.sjc02.lab.cisco.com:enp63s0:none
Note: Next line or enter key in the above commands are added for readability. it should be typed as one line.
Figure below shows the RHCOS install in worker node
Once the worker node is up, you can ssh to worker node and watch the status by running the following command
# ssh core@worker0.ocp4.sjc02.lab.cisco.com
# journalctl -b -f
Troubleshooting
Following are the troubleshooting tips in case if you experience any issues during the install
Pulling debug from installer machine. log files help in finding issues during the install.
# ./openshift-install gather bootstrap --bootstrap bootstrap.ocp4.sjc02.lab.cisco.com  --master master0.ocp4.sjc02.lab.cisco.com --master master1.ocp4.sjc02.lab.cisco.com --master master2.ocp4.sjc02.lab.cisco.com
# tar xvf log-bundle-20200720162221.tar.gz
look for container logs in
/root/ocp-install/log-bundle-20200720162221/bootstrap/containers
Look for bootstrap logs in
You can also ssh to the node such as bootstrap as shown below and look for any issues by running the following command
[root@rhel1 ocp-install]# ssh core@bootstrap.ocp4.sjc02.lab.cisco.com
Red Hat Enterprise Linux CoreOS 45.82.202007141718-0
  Part of OpenShift 4.5, RHCOS is a Kubernetes native operating system
  managed by the Machine Config Operator (`clusteroperator/machine-config`).
WARNING: Direct SSH access to machines is not recommended; instead,
make configuration changes via `machineconfig` objects:
  https://docs.openshift.com/container-platform/4.5/architecture/architecture-rhcos.html
This is the bootstrap node; it will be destroyed when the master is fully up.
The primary services are release-image.service followed by bootkube.service. To watch their status, run e.g.
Last login: Tue Jul 21 00:14:00 2020 from 10.16.1.31
[systemd]
Failed Units: 1
  rdma.service
[core@bootstrap ~]$ journalctl -b -f -u release-image.service -u bootkube.service
If you are experiencing DNS issues. Run nslookup to see if they can be resolved. Pay special attention to etcd SRV records.
If you are running etcd related issues. Look for clock for nodes. Masters clocks are usually in sync. Bootstrap clock could be out of sync with masters. you can use the following command to verify. if you find clock out of sync by running the following, fix it.
[root@rhel1 ocp4.3-install]# for i in {bootstrap,master0,master1,master2}; do ssh core@$i.ocp4.sjc02.lab.cisco.com date; done;
If you experience any issues where worker node is not getting registered with master nodes (cluster) or forbidden  user "system:anonymous" access while connecting to API server, check to see if you have any pending CSR in queue. if so, approve those CSR, you can use the following commands
[root@rhel1 ocp-install]# oc get csr -o name
[root@rhel1 ocp-install]# oc get csr -o name | xargs oc adm certificate approve
If you experience any certificate related issues, look into if certificate is not expired. Following command will come handy for this purpose.
[core@bootstrap ~]$ echo | openssl s_client -connect api-int.ocp4.sjc02.lab.cisco.com:6443 | openssl x509 -noout -text
Finishing up the install
Once the bootstrap process is finished, you'll see the following message.
Remove the bootstrap from /etc/haproxy/haproxy.cfg file and restart haproxy service.
Validate Install
# export KUBECONFIG=auth/kubeconfig
# oc get nodes
oc get nodes.png # oc get pods --all-namespaces
Web console
The OpenShift Container Platform web console is a user interface accessible from a web browser. Developers can use the web console to visualize, browse, and manage the contents of projects.
The web console runs as a pod on the master. The static assets required to run the web console are served by the pod. Once OpenShift Container Platform is successfully installed, find the URL for the web console and login credentials for your installed cluster in the CLI output of the installation program
To launch the web console, get the kubeadmin password. It is stored in auth/kubeadmin-password file
Launch the OpenShift console by typing the following in the browser.
https://console-openshift-console.apps.ocp4.sjc02.lab.cisco.com
Specify username and password. Username as kubeadmin and password retrieved from auth/kubeadmin-password file.
Click Compute-->Nodes
Click on one of the Node
Adding RHEL compute machines to an OpenShift Container Platform cluster
In OpenShift Container Platform 4.5, you have the option of using Red Hat Enterprise Linux (RHEL) machines as compute machines, which are also known as worker machines, in your cluster if you use a user-provisioned infrastructure installation. You must use Red Hat Enterprise Linux CoreOS (RHCOS) machines for the control plane, or master, machines in your cluster.
Note: if you choose to use the RHEL compute machines in your cluster, it is assumed that you take the responsibility of all OS lifecycle, management, and maintenance; which also include performing upgrades, patches, and all other OS tasks.
Prerequisites
  • You must have active OpenShift Container Platform subscription on your Red Hat account
  • Base OS should be RHEL 7.7 – 7.8
  • Networking requirement. RHEL compute host must be accessible from control-plane
        Note: Only RHEL 7.7-7.8 is supported in OpenShift Container Platform 4.5. You must not upgrade your compute machines to RHEL 8.
Install RHEL
  1. Download Red Hat Enterprise Linux 7.8 Binary DVD iso from access.redhat.com
  2. Activate the virtual media in  Cisco UCS Manager KVM and map this iso file. Power cycle the server for it to boot from virtual media.
  3. Follow along the instructions of installing RHEL 7.8
  4. Under network and host name, specify as shown in Figure
  1. Reboot to finish the install.
Before you add a Red Hat Enterprise Linux (RHEL) machine to your OpenShift Container Platform cluster, you must register each host with Red Hat Subscription Manager (RHSM), attach an active OpenShift Container Platform subscription, and enable the required repositories.
# subscription-manager register --username <username> --password <password>
#  subscription-manager list --available --matches '*openshift*'
#  subscription-manager attach --pool=<pool id>
#  subscription-manager repos --disable="*"
#  yum repolist
#  subscription-manager repos     --enable="rhel-7-server-rpms"     --enable="rhel-7-server-extras-rpms"     --enable="rhel-7-server-ose-4.5-rpms"
Stop and disable firewall on the host
# systemctl disable --now firewalld.service
Note: You must not enable firewalld later. Doing so will block your access to OCP logs on the worker node
Prepare the installer/bastion node to run the playbook
Perform the following steps on the machine that you prepared to run the playbook. In this deployment, I used the same installer host to setup Ansible.
Make sure you have ansible installed. This document does not focus on installing Ansible.
Note: Ansible 2.9.5 or later is required. you can run # yum update ansible if required
Verify ansible by running the following command.
# [root@rhel1 ocp-install]# ansible localhost -m ping
localhost | SUCCESS => {
    "changed": false,
    "ping": "pong"
Setup openshift-ansible, perform the following:
# git clone https://github.com/openshift/openshift-ansible.git
Create host file for newly added worker nodes
[root@rhel1 ocp-install]# cat  openshift-ansible/inventory/hosts
[all:vars]
ansible_user=root
#ansible_become=True
openshift_kubeconfig_path="/root/ocp-install/auth/kubeconfig"
[new_workers]
Copy installer SSH key to RHEL host for password less login
# ssh-copy-id -i ~/.ssh/id_rsa.pub root@worker0.ocp4.sjc02.lab.cisco.com
Before running the playbook make sure you can access the worker node via ansible ping.
$ ssh-copy-id -i ~/.ssh/id_rsa.pub root@worker0.ocp4.sjc02.lab.cisco.com
$ ansible all -i openshift-ansible/inventory/hosts -m ping
Run the playbook
[root@rhel1 ocp-install]# ansible-playbook -i openshift-ansible/inventory/hosts openshift-ansible/playbooks/scaleup.yml
Install will begin as shown
You can ssh to worker node and can also watch the progress or any issues with the following command
# journalctl -b -f
# tail -f /var/log/messages
Newly added worker node will reboot at some point.
Install will complete successfully if no issues occurred as shown below.
Run the following to verify if the worker node joined the cluster
# oc get nodes
Launch the web console and verify if worker node is added.
Sample Application Deploy in OpenShift
MySQL
In this example, I will be deploying MySQL and exposing the service to create a route to validate the install.
  1. Login to OCP and create a new project
# oc new-project p02
  1. Create a service by using oc new-app command
# oc new-app \
    --name my-mysql-rhel8-01 \
    --env MYSQL_DATABASE=opdb \
    --env MYSQL_USER=user \
    --env MYSQL_PASSWORD=pass \
    registry.redhat.io/rhel8/mysql-80
Run the following command to verify if the service is created
# oc get svc
  1. Expose the service to create the route.
[root@rhel1 ocp-install]# oc expose svc/my-mysql-rhel8-01
route.route.openshift.io/my-mysql-rhel8-01 exposed
  1. You can get the route information from the following command
# oc get route my-mysql-rhel8-01
  1. Login to worker node and run the following command.
# curl 172.30.23.171:3306
The examples in this section use a MySQL service, which requires a client application. If you get a string of characters with the “Got packets out of order” message as shown in the below figure means you are connected to the service.
# mysql -h 172.30.23.171 -u user -p
Enter password:
Welcome to the MariaDB monitor.  Commands end with ; or \g.
MySQL [(none)]>
Jupyter Notebook
Create a notebook image using the supplied image stream definition as below
# oc create -f https://raw.githubusercontent.com/jupyter-on-openshift/jupyter-notebooks/master/image-streams/s2i-minimal-notebook.json
Once the image stream definition is loaded, the project it is loaded into should have the tagged image:
s2i-minimal-notebook:3.6
Deploy the minimal notebook using the following command under the same project created earlier as “p02”
# oc new-app s2i-minimal-notebook:3.6 --name minimal-notebook --env JUPYTER_NOTEBOOK_PASSWORD=mypassword
The JUPYTER_NOTEBOOK_PASSWORD environment variable will allow you to access the notebook instance with a known password.
You need to expose the notebook by running the following command by creating the route.
# oc create route edge minimal-notebook --service minimal-notebook --insecure-policy Redirect
To see the hostname, which is assigned to the notebook instance, run:
# oc get route/minimal-notebook
You can also verify the successful creating of the notebook in the web console UI
Click on the location URL under Routes section or launch the browser, type https://minimal-notebook-p02.apps.ocp4.sjc02.lab.cisco.com/. Notebook will be launched in the browser as shown.
Type the supplied password such as “mypassword” set earlier at the time of creation of this application.
Now you can start coding in Jupyter notebook. For example, click New and then Python 3 as shown below
Now, you are ready to code in Python as shown below.
