취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
41
의견
How many of you have spent countless hours installing operating systems on bare metal? If you're like me you've been through creating a master CD image, PXE booting, and all manner of fun tools like Cobbler, Razer, xCAT, Rocks, crowbar, warewulf... just to name just a few!  If you're like me, you also consider yourself a failure anytime you have to do it manually or even worse burn actual DVDs!  These methods have actually been around for a long time.  However, in UCS 2.2(2c) in 2014 Cisco quietly introduced a new way to automatically install operating systems that most people still don't know about.
Venerable PXE
The art of PXE booting to install operating systems has been in use for as long as I've been in IT.  It is the gold standard for managing hundreds or thousands of bare metal operating systems and I've personally used it on clusters ranging from 10 to 1,600 node systems.  PXE booting involves having the computer boot up and instead of immediately looking at its local disk for an operating system, it instead looks at the network for direction.  PXE images themselves have undergone quite a transformation in the last few years.  Before you had to use the TFTP protocol only,  but with the advent of gPXE and the follow-on iPXE you can now use HTTP, iSCSI, or even FCoE to remotely boot.
Issues with PXE
But there are issues with setting up a PXE environment which is why most enterprises still install using manual methods.  These challenges include:
  • DHCP Setup - In order for PXE to work, you need to know the MAC address or UUID of the server you wish to install and populate the DHCP server with the files and commands to install it.
  • HTTP Setup - If using iPXE then DHCP needs to be coordinated with where the HTTP server is serving out the installation media.
  • Updates over time - Servers change and installation media does as well.  Keeping these systems in sync can be challenging
  • Network Setup - PXE only works if there are solid network settings in place.  Often doing this setup and ensuring correctness can take more time than actually installing the OS and many enterprise networks do not want the additional overhead of these services (which can do much disruption) running on top of the network.
All of this coordination seems like a lot to configure on an enterprise network, especially if the time taken to set this up takes longer than just installing the operating system to begin with!
Advantages of Automated Installations
Even with the problems of setting up a PXE environment there are still many advantages to be gained by having an automated installation environment set up for your servers.  These include:
  • Immutable Infrastructure - This is the idea that instead of doing patch management, we simply blow all the old stuff away and install a fresh OS with the latest updates on it.  This can work great for VMware, Windows, and Linux.  This way you are assured that your Operating system is fresh and clean without legacy bloat.
  • Consistency of Images - If your server farm provides a private cloud for your applications, ensuring the servers are consistent goes a long way to making sure performance and libraries are available for those applications to run better.
  • Quick Changing - If business dictates that certain servers are no longer necessary for other operations they can be provisioned to act in a different capacity.  Automated installation can change the identity of a server from being an ESX server to being a Hyper-V server in very little time.
vMedia Policy FTW!
It would be nice then if we could get the advantages of Automated Installation capabilities without the disadvantages of having to set up a complicated PXE environment or install any of these other tools like Cobbler, etc.  This is where UCS shines and is unsurpassed by any other platform.
A vMedia policy is a policy that states what installation media should be automatically mounted by a service profile before it boots up.  The only requirements to make an automated installation is to create a vMedia policy, attach it to a service profile, and then have a web server where virtual media can be accessed.
Creating a vMedia policy can be done on any UCS with firmware 2.2(2c) or greater.  In the server tab, there is a section to create vMedia. In the example below, we are creating a policy for our Kubernetes bare metal nodes, so we call the policy "kube"
We can then add two vMedia mounts.
  1. A modified ISO image for installation
  2. An image created that contains only a kickstart file
The ISO image is the same for all nodes.  In this case, the ISO image is available on one of our internal web servers at http://192.168.2.2/install/centos7.3-boot.iso
A kickstart file is unique for each service profile.  Since one of my service profiles is named "kube01", I have created an image that is available at http://192.168.2.2/install/kube01.  Setting the vMedia profile as shown below makes this possible:
We of course could instead script all of this with something like the below, using the UCSM Python SDK
def createKubeVirtualMedia(handle):
    print "Adding Virtual Media Policy"
    from ucsmsdk.mometa.cimcvmedia.CimcvmediaMountConfigPolicy import CimcvmediaMountConfigPolicy
    from ucsmsdk.mometa.cimcvmedia.CimcvmediaConfigMountEntry import CimcvmediaConfigMountEntry
    mo = CimcvmediaMountConfigPolicy(name="kube",
        retry_on_mount_fail="yes",
        parent_mo_or_dn="org-root",
        policy_owner="local",
        descr="Kubernetes Boot Media")
    mo_1 = CimcvmediaConfigMountEntry(parent_mo_or_dn=mo,
        mapping_name="CentOS7",
        device_type="cdd",
        mount_protocol="http",
        remote_ip_address="192.168.2.2",
        image_name_variable="none",
        image_file_name="centos7.2-boot.iso",
        image_path="install")
    mo_2 = CimcvmediaConfigMountEntry(parent_mo_or_dn=mo,
        mapping_name="kickstartImage",
        device_type="hdd",
        image_name_variable="service-profile-name",
    handle.add_mo(mo, modify_present=True)
    try:
        handle.commit()
    except UcsException as err:
        if err.error_code == "103":
            print "\talready exists"
The last step is to create a boot policy that installs from the Hard Drive first, and then if no Operating System is found on the Hard Drive, to then use the virtual media to install.  This is done as shown below.  We first boot from the local drive and then add the CIMC mounted virtual media as the secondary boot option.
Attaching this to a service profile then gives us all we need for automated operating system installations!  By attaching a Disk Scrub policy to automatically scrub the disks after the service profile is assigned we can then create other vMedia profiles to install other operating systems by simply assigning them to other Service Profile Templates.  In this way you could have complete control over multiple operating systems that boot up and change them faster than ever.
If you've been following along all the way up to this point the one question you may have is: How do I create the Kickstart Images and how do I create the CentOS / Red Hat boot media to automatically run a kickstart with no manual intervention?  We've got you covered.  Head on over to our Github pages to have a look.  There you will see how we actually create the ISO files as well as show screen shots from the classic UCS Manager.  We've also created a video to show how this works.  Once the service profiles are created the entire process is automatic with no manual intervention other than pulling up KVM consoles so we can watch it boot.
Please let us know if you have any issues!
16 의견
