01-13-2016 04:51 AM - edited 03-01-2019 12:32 PM
Hello friends! I need to know the speed (rpm) of the fans, recommended by Cisco. At the time, they are set in 7320 rpm, but it is very noisy
Thanks a lot,
Regards!
01-13-2016 05:43 AM
Hi Fede,
What type of hardware is in your chassis? Also what UCS firmware is running for the environment, all these are essential to know what the correct fan speed should be set at.
01-14-2016 09:27 AM
01-20-2016 06:04 AM
Hello, i solved the problem doing a upgrade to 2.2.
