All part numbers for a UCS installation
ADAman
zsafawi
To ensure that all solution components are ordered, you'll need to use one of the below tools. Also, make sure to adhere to design guidelines for other components.
Netformx DesignXpert
http://www.cisco.com/go/designxpert
Cisco Solution Expert
http://www.cisco.com/go/sx%7C
Cisco Commerce Workspace
http://forums.cisco.com/ecom/web/ccw
You can also open a case with PRH (Pre-Seller Helpline) team and they can help with part numbers.
For Planning, Design and Implementaion
http://www.cisco.com/go/pdihelpdesk
-HTH
Zouheir
zsafawi
-HTH
Zouheir
