B200 M3 - Adapter Firmware recovery
Richard Simmons
Level 3
Level 3
I have been downgrading the firmware on some B200 M3 servers to match the rest of the estate, one of the blades in Chassis 4 had an issue during the process and now the Adapter is showing no firmware and a critical fault on the sever. I have tried decommissioning the Chassis and the server but the issue persists and i don't know how to recover the Adapter firmware or if its even possible?
Is there a way to fix this or does it need to be replaced?
Richard
Kirk J
Hi Richard.
You'll want to open a TAC case and see if anything can be done aside from replacing the adapter.
Kirk...
Kirk J
Hi Richard.
Kirk...
Richard Simmons
Level 3
Level 3
Thanks Kirk, raised a TAC case and it required hardware replacement .
Richard
