B200 M3 memory stuck at 1333MHz in performance mode
Brad_80
We have 2 B200 M3s in a new deployment running 2.0(3a). The B200s are configured with 64GB using 8GB DIMMs, using BANK 0 of each channel. We've deployed a BIOS policy specifying performance mode for LV DDR, and confirmed this setting took effect within the BIOS, yet the memory continues to run at 1333MHz. When looking at the server inventory, the DIMMs are reported as dual rank 8GB 1600MHz DIMMs. We've tried forcing the DIMMs to low-voltage mode and back to performance mode to no avail.
In other UCS environments, we've deployed these same blades with the same memory configuration and BIOS policy and had no issues getting the RAM to run full speed. We're not using any kind of power capping either.
Thoughts?
mtimm
Hi Brad,
What CPU is being used?  3 of the supported CPU's for the B200-M3 do not support 1600 Mhz:
http://www.cisco.com/en/US/docs/unified_computing/ucs/hw/chassis/install/B200M3.html#wp1028500
Mike
mtimm
Hi Brad,
Mike
Thanks Mike. The CPU is an E5-2620, which per the link you provided, is limited to 1333 MHz.
