12-22-2015 02:27 PM - edited 03-01-2019 12:31 PM
I've been banging my head against this wall for long enough, so I am hoping someone can shed some light on where things have gone so wrong.
I recently deployed a UCS environment consisting of the following:
The FIs uplink to a pair of 3850s (stacked).
The hosts and VMs have been exhibiting intermittent connectivity issues and poor performance. Consistently, if I reboot the host, ESXi management connectivity is lost until I reset the management network within ESXi.
From the vSphere side, I have a pair of vmnics on the management VLAN as well as other production VLANs, and a pair of vmnics for iSCSI. One standard vSwitch for mgmt. and production traffic (teaming based on Port ID), and a second standard vSwitch for iSCSI traffic (no teaming).
I have tried a number of things to troubleshoot and resolve the issue. Recently, I discovered the critical issue with 2.2(5a) and poor performance on B200 M4 blades. I upgraded the software to 2.2(5b) this past weekend with no resolution.
At this point, if I reboot a host with two vmnics on the mgmt. vSwitch, the host will have NO mgmt. connectivity. If I reset the management network, it responds to pings. If I remove a vmnic and reboot, everything reboots happy, albeit without redundancy.
If I leave the two vmnics on the mgmt. vSwitch and reboot, no connectivity. But if I disable one of the NICs in UCS manager, it starts to respond to pings. As soon as I re-enable the NIC in UCSM, pings are dropped.
So, I'm at a loss. Any insight? Thanks
Solved! Go to Solution.
12-22-2015 02:54 PM
Greetings.
Sounds like you may be hitting https://tools.cisco.com/bugsearch/bug/CSCuv00089/?reffering_site=dumpcr
You might want to open a tac case to confirm. If that is the issue, then an upgrading to 2.25c or higher will resolve.
Kirk...
12-22-2015 02:54 PM
Greetings.
Kirk...
12-22-2015 05:30 PM
Yep, that looks to be it. vmk0 (mgmt) was taking the MAC of nic1. recreated vmk0 and everyone's happy. Thanks!
p.s. 2.2(5c) and (6c) are not publicly available, correct?
12-22-2015 06:00 PM
Currently 2.2(5d) and 2.2(6e) are currently the latest and available for download.
Kirk..
