B250 M2 Fault Light
sevensixtwo187
I have a B250 M2 with the amber fault light /!\ on the right blinking. The thing is I am not showing any faults with this blade or in my cluster as a whole.
Just wanted to see if any one had a quick thought on this before I go to TAC.
Thank you,
dbrzecze
Check your SEL log on that blade.  I'm having the same issue and I can't come to a conclusion of what it is.  I'm thinking that it's a battery issue.
Thanks for the input. I will have a closer look at it.
I am finding this in the SEL log for that blade starting on the 5th of this month:
3ae | 09/05/2011 05:24:48 | BMC | Memory DDR3_P1_C4_ECC #0xa5 |  | read 253 correctable ECC errors on Dimm 20 | Asserted
   3af | 09/05/2011 05:24:48 | BMC | Memory DDR3_P1_C4_ECC #0xa5 | Upper critical - going high | Asserted | Reading 253 > Threshold 10 error
   3b0 | 09/05/2011 05:24:48 | BMC | Memory DDR3_P1_C4_ECC #0xa5 | Upper Non-recoverable - going high | Asserted | Reading 253 > Threshold 15 error
   3b1 | 09/05/2011 05:24:48 | BMC | Platform alert LED_BLADE_STATUS #0xcc | LED is blinking fast | Asserted
   3b2 | 09/05/2011 05:24:49 | BMC | Platform alert LED_BLADE_STATUS #0xcc | LED color is amber | Asserted
   3b3 | 09/05/2011 05:24:49 | BMC | Platform alert LED_BLADE_STATUS #0xcc | LED is on | Deasserted
   3b4 | 09/05/2011 05:24:49 | BMC | Platform alert LED_BLADE_STATUS #0xcc | LED color is green | Deasserted
4ba | 09/14/2011 05:38:02 | BMC | Memory DDR3_P1_C4_ECC #0xa5 |  | read 253 correctable ECC errors on Dimm 20 | Asserted
   4bb | 09/14/2011 05:38:08 | BMC | Memory DDR3_P1_C5_ECC #0xa6 |  | read 253 correctable ECC errors on Dimm 21 | Asserted
Followed by this every day since:
