Blade server managing instance
muhammadshamim1
Community Member
hey, i am working from data center directly connecting my laptop to FI-B (the master).
i need to open KVM of one of the blades, whose managing instance is FI A
How do i change the managing instance from FI-A to FI-B?
Note - configured only out of band.
Thank you.
-Shamim
AFROJ AHMAD
 As per my understanding ,if you have the access to Primary FI.
you should be able to launch the UCSM via GUI. if yes you can launch the KVM of any of the server you want to .
Thanks-
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks Afroz for the reply.
But it doesn't work as you explained.
For all my servers which has managing instance FI, which is subordinates, if i need to open the KVM, i have to connect from LAN and access Virtual IP.
But when I connect my laptop directly to the master FI mgmt port and access Virtual IP, it opened KVM for all servers which has managing instance FI as Primary. And for all servers which has managing instance as subordinate, i get network connection error and i see that i cant even ping the out of band IP. 😞
Thank you.
-Shamim
