c-200m1 doesn't allow ip management after KVM session
dani_bosch
Our customer is having following issue: he connects locally to the KVM of a c-200m1 through the serial/vga ports, and right afterwards he can't access remotely to the CIMC via IP, unless he reboots the server. Is that a common behavior of these servers?? (I don't think so...)
Services are enabled and running.
What exactly happens when they try to access CIMC via web browser ?
7 Replies 7
padramas
Hello Dani,
Can you please share CIMC version ?
What exactly happens when you login to CIMC and click on KVM console ?
Padma
CIMC version is 1.4(2).
Problem is customer can ping the CIMC but cannot access it via web
Hello Dani,
Is TCP & port 80 / 443 traffic allowed between client and server ?
SSH into CIMC and share the output of following commands
show kvm
show http
Padma
Ports are allowed...in fact, if customer reboots the server, he can then access CIMC and KVM successfully
Here you have the show outputs:
GCSAVMS08#
GCSAVMS08# show kvm
Encryption Enabled Local Video      Active Sessions Enabled KVM Port
no                 yes              0               yes     2068
GCSAVMS08# show http
HTTP Port  HTTPS Port Timeout  Active Sessions Enabled HTTP Redirected
80         443        1800     0               yes     yes
GCSAVMS08#
Padma, customer is telling me he prefers not to reproduce the error again because he prefers having this minor error rather than potentially causing a bigger one when trying to reproduce the minor one.
So we'll leave it like this. Thanks for your help anyway
