C220 M4 Physical NICs not showing
kamalia
Hi Everyone,
I have a C220 M4 that was previously connected to UCS and is now being used as a standalone server.
CIMC is configured and accessible via KVM. Two Ethernet cables are connected and show up in CIMC under External Interfaces.
However, the OS only shows vNICs — the physical interfaces aren’t detected.
Any ideas?
What do you have in the vNIC tab of the CIMC? I don't think the physical NIC;s are exposed to the OS. You might also need to use HUU to update all the firmware depending on the version. Have you tried resetting the MLOM settings to default?
Agree with Elliot.
Only the vNICs and vHBAs(if created) will be exposed to the OS, not the physical uplinks.
The OS would need to have proper Cisco VIC card drivers present as well.
Kirk...
