change chassis port on same ucs
Tatone86
Hi team,
I would like to chage port on my fabric interconnect:
I have a chassis with 8 port on iom connected on fabric interconnect.
Now the order of port connected on fabric interconnect it's wrong, i would like to move this port form port number 9 to port number 11.
The other port remaining with current status.
Wich impact it's possible to find?
Thanks in advance
Kirk J
Changing up the links a specific IOM is using, will require you to re-ack the individual IOM (Older versions of UCSM required whole chassis re-ack)
If you are using link aggregation for you chassis link discovery, then impact should be minimal.
As long as you have storage multipath setup (i.e FC sees both side A and side B for lun paths) and network teaming for ethernet, then this should not be very impacting.
Kirk...
