Chassis /FEX Discovery policy - Error
JDMils
I have noticed the following error in my UCSM environment:
Chassis discovery policy conflict: Link IOM 3/1/1 to peer port A:N/A/1/76 not configured
IOM 3/1/1 is the following:
Type: FEX
Model: Cisco Nexus 2232PP
Fabric Ports:
1/1, sys/fex-3/slot-1/fabric-pc/pc-1027/ep-slot-1-port-1, sys/switch-A/slot-1/switch-ether/port-76, Ack=Un-Acknowledged
1/2, sys/fex-3/slot-1/fabric-pc/pc-1027/ep-slot-1-port-2, sys/switch-A/slot-1/switch-ether/port-77, Ack=OK
1/3, sys/fex-3/slot-1/fabric-pc/pc-1027/ep-slot-1-port-3, sys/switch-A/slot-1/switch-ether/port-78, Ack=OK
1/4, sys/fex-3/slot-1/fabric-pc/pc-1027/ep-slot-1-port-4, sys/switch-A/slot-1/switch-ether/port-79, Ack=OK
So 3 of the fabric ports from the FEX to the FI-A are OK, the other does not seem to be and thus the logged fault.
This is Fabric A. I have another FEX which has 4 fabric ports connected to FI-B and they are all connected OK.
FIs are: Model: Cisco UCS 64108
Is this simply a case of clicking "Acknowledge Fex" on the FEX unit and if so, will this cause any type of outage?
RedNectar
Hi @JDMils ,
Definitely the first step is to re-acknowledge the FEX.  But when you do, the existing traffic will be re-balanced across all four links, so there may be a second or two interruption to existing flows.
RedNectar aka Chris Welsh.
RedNectar
Hi @JDMils ,
Thanks- that fixed it. I just was not sure how a re-ack would affect the server's operation.
RedNectar
HI @JDMils ,
Has this problem been solved or do you need more help?
If your question has been answered, it is a great idea to mark the question as being answered.  This helps:
  1. others with a similar problem find the correct answer
  2. people who look for "unanswered" questions to answer finding this
  3. prevent your question from becoming a "dead thread"
Re-acknowledging the FEX has fixed the issue, thank you.
