CIMC Certificate Issue
silvervoip
Greetings,
I have just noticed that certificate of CIMC has expired. I logged as admin but could not able to see some options as described in documentations.
Product Name: UCS C240 M4SX
any possibility to see which certificate has expired?
Documentation or URL would be great if you can point me out
Thank you.
teljxr1
If one need to generate a certificate via the CLI after expiration:
Note - once the CIMC certificate expires, you will not be able to 'https://' to the CIMC controller.
ssh to the CIMC via IP address
Once you are on the prompt below (the 'x' is to hide things):
C220-FCHxxxxxxxx#scope certificate
C220-FCHxxxxxxxx# / certificate #show detail
You will see the below - copy it somewhere:
Certificate Information:
    Serial Number: D72XXXXXXXXXXXXB
    Subject Country Code (CC): US
    Subject State (S): California
    Subject Locality (L): San Jose
    Subject Organization (O): Cisco Self Signed
    Subject Organizational Unit (OU): PID:UCSC-C220-M4S SERIAL:FCHXXXXXXXX
    Subject Common Name (CN): C-series CIMC
    Issuer Country Code (CC): US
    Issuer State (S): California
    Issuer Locality (L): San Jose
    Issuer Organization (O): Cisco Self Signed
    Issuer Organizational Unit (OU): PID:UCSC-C220-M4S SERIAL:FCHXXXXXXXX
    Issuer Common Name (CN): C-series CIMC
    Valid From: Jan 19 12:26:53 2018 GMT
    Valid To: Jan 18 12:26:53 2023 GMT
220-FCHXXXXXXXX /certificate # generate-csr
(When generating the certificate, you will use the 'certificate detail' to input information as it asks for it, such as the Common Name, etc.:)
Once completed, it will ask you to 'Continue to generate CSR?[y|N]'. - you will say 'y'
This will take about 3 minutes to generate.. Once generated, it will ask you:
Continue to self sign CSR and overwrite the current certificate?
All HTTPS and SSH sessions will be disconnected. [y|N] - you will say 'y'
At this point, the CIMC will be rebooted... this will take a few seconds.  You will need to reconnect to the CIMC, BUT, you will now be able to 'https://' to it at this point.
Jose
