CIMC PCI Adapter LOM Option Not Loading Issue
JIN3
(C240 M5)
In CIMC, there is an issue where the LOM option under the PCI Adapter tab is displayed as "Not Loaded." However, there are no symptoms or indications in the system error logs.
Why is this happening?
Should this be considered a fault, and is it likely to cause issues in the future?
0 Replies 0
