Cisco FI 6248UP to Nexus 5Ks connectivity
Luke Akpor
Hi Guys,
Can someone please advise me the best way to implement the following connections?
I am trying to connect a pair of Fabric Interconnect (6248UP with 32ports) to a pair of Nexus 5Ks (5548UP) with the 5Ks connecting directly to the Storage (EMC). This is for a small deployment. The 5Ks will be running the full Fabric Services such as configuring the zoning, etc. By the way vPC will running between the FIs and the 5Ks for ethernet traffic only.
My question are:
1.       What type of connection should I use between the 6248UP-FIs and the pair of 5Ks. Should I configure say 2 of the ports on the FIs as FC Uplink ports and use an FC SFP (e.g DS-SFP-FC8G-SW) for the connections? This way both the 5K and the FI will be running native FC in-between at 8G. Is this the best practice?
2.       Is it possible to run FCoE from the FI directly to the 5Ks and just running the native FC from the 5K to the EMC Storage?
3.       Is there any Cisco doc or someone's blog I can be pointed to that could help in the best practice for such scenario?
Any answers or further suggestions will be appreciated.
Thanks in advance.....
2 Accepted Solutions
Hello Luke,
You can upgrade UCSM to 2.1.1a
Here is sample config for FCoE between FI and N5K switch.
#####  On UCSM 2.1  ######
1) FC end mode
2) Configure a port as FCoE uplink  and assign the interface to VSAN 10
http://www.cisco.com/en/US/products/ps10281/products_installation_and_configuration_guides_list.html
## Verifying the output
6248-01-A(nxos)# show run int vfc 1255
interface vfc1255
  bind interface Ethernet1/24
  switchport mode NP
  no shutdown
##### Configuration on N5K  #####
1) Enable NPIV,fcoe and lldp features
2) Create vlan, configure ethernet and VFC interfaces
----------- sample configuration ----------------
conf t
vlan 1001
fcoe vsan 10
interface Ethernet1/19
switchport mode trunk
spanning-tree port type edge
spanning-tree bpdufilter enable
no shutdown
int vfc 14
bind interface Ethernet1/19
switchport trunk allowed vsan 1
switchport trunk allowed vsan add 10
no shutdown
vsan database
vsan 10 interface vfc 119
####  Comands to verify the configuration  #####
show feature
show vlan
show fcoe vlan
show int vfc 119
show fcoe database
show flogi table
Padma
Add your second boot target "fc1" (guessing at the vHBA name) with the WWN of Fabric B's target.
Robert
20 Replies 20
padramas
Hello Luke,
With UCSM 2.1.1, we can have FCoE between FI and N5K.
We have Flexpod design guide ( Netapp storage ) and you make use of information that fits your deployment.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/Virtualization/flexpod_deploy.html
Padma
Thanks Padma for the response and for the useful link,
I will have a good  read through the doc later on, but one thing I did notice in the diargam is the FIs where still connected to the N5Ks using native FC which I guess is due to the FI being the order model running the older code which is fine.
Now that the UCSM2.1.1 supports FCOE between the FI and the N5K, I think my first step will be to upgrade to this latest code and test.
Are you abel to confirm what a possible configuration will be needed on the FI to support FCoE basically carrying the VSAN traffic accross to the N5Ks? Would I need to configure vfc, VSANs, VLANs on the FIs just the same way I would on the N5Ks?
Any possible link to this latest depolyment scenario will be appreciated.
Please note my intended plan is FI -----(FCoE)-----N5K-------(FC)------EMC.
Thanks for your help
Luke
Hello Luke,
1) FC end mode
interface vfc1255
  switchport mode NP
  no shutdown
conf t
vlan 1001
fcoe vsan 10
no shutdown
int vfc 14
no shutdown
vsan database
show feature
show vlan
show fcoe vlan
show int vfc 119
show fcoe database
show flogi table
Padma
Thanks Padma,
Trully appreciate your response and support.
Luke
Hi Padma,
Just to give you some heads up on what I have done so far and to seek some more advice
I have upgraded the FIs to version 2.1.1b the lastest code and now running FCoE from the FI to both Nexus 5Ks with the config as below.
This issue now is for some reasons I can see all the vhba WWPN on Fabric A but not on Fabric B and the config is exactly the same. Is there anything i need to do on  the UCS side of things to enable the initiators to login to fabic B.
Show flogi database on N5K1 shows as below:
N5K-SW1(config)# sh flogi database
INTERFACE        VSAN    FCID           PORT NAME               NODE NAME
fc1/31           1010  0x3b00ef  50:06:01:68:3e:e0:1c:e0 50:06:01:60:be:e0:1c:e0
fc1/32           1010  0x3b01ef  50:06:01:61:3e:e0:1c:e0 50:06:01:60:be:e0:1c:e0
vfc1010          1010  0x3b0000  22:d0:54:7f:ee:c0:74:bf 23:f2:54:7f:ee:c0:74:81
vfc1010          1010  0x3b0004  20:00:00:25:b5:00:02:0f 20:01:00:25:b5:00:01:6f
vfc1010          1010  0x3b0005  20:00:00:25:b5:00:02:2f 20:01:00:25:b5:00:01:9f
vfc1010          1010  0x3b0006  20:00:00:25:b5:00:01:ff 20:01:00:25:b5:00:01:7f
vfc1010          1010  0x3b0007  20:00:00:25:b5:00:00:9f 20:01:00:25:b5:00:01:8f
Total number of flogi = 7.
N5K-SW1(config)#
N5K-SW2(config-if)# sh flogi database
fc1/31           1020  0x7900ef  50:06:01:69:3e:e0:1c:e0 50:06:01:60:be:e0:1c:e0
fc1/32           1020  0x7901ef  50:06:01:60:3e:e0:1c:e0 50:06:01:60:be:e0:1c:e0
vfc1020          1020  0x790000  22:d1:54:7f:ee:c0:73:ff 23:fc:54:7f:ee:c0:73:c1
Total number of flogi = 3.
N5K-SW2(config-if)#
See configs as below, and thanks for your help in advance:
N5K1
vlan 1010
  fcoe vsan 1010
  name SAN_A_VLAN
vsan database
  vsan 1010 name "SAN_A"
interface port-channel10
  switchport trunk allowed vlan 1010
  speed 10000
interface port-channel11
  switchport trunk allowed vlan 1-1009,1021-4094
  speed 10000
  vpc 11
interface port-channel21
  speed 10000
  vpc 21
interface vfc1010
  bind interface port-channel10
  switchport trunk allowed vsan 1010
  no shutdown
vsan database
  vsan 1010 interface vfc1010
  vsan 1010 interface fc1/31
  vsan 1010 interface fc1/32
N5K2
vlan 1020
  fcoe vsan 1020
  name SAN_B_VLAN
vsan database
  vsan 1020 name "SAN_B"
  speed 10000
  vpc 11
interface port-channel20
  switchport trunk allowed vlan 1020
  speed 10000
  speed 10000
  vpc 21
interface vfc1020
  bind interface port-channel20
  switchport trunk allowed vsan 1020
vsan database
  vsan 1020 interface vfc1020
  vsan 1020 interface fc1/31
  vsan 1020 interface fc1/32
Hello Luke,
Please share the output of following command for a server where HBA configured for Fabric B has not logged in.
UCS-FI# show service-profile circuit server x/y ==> X and Y are Chassis & Blade numbers
UCS-FI# connect nxos b
UCS-FI(nxos) # show npv flogi-table
UCS-FI(nxos) # show int vfc
Padma
Hi Padma,
Thanks for your response. Please see below info as requested.
I could see the link state is error on fabric B but not sure why. The configs on both is the same?
N6K-FI1-B# show service-profile circuit server 1/1
Service Profile: esx1_1
Server: 1/1
    Fabric ID: A
        VIF        vNIC            Link State  Oper State Prot State    Prot Role   Admin Pin  Oper Pin   Transport
               728 eth0            Error       Error      No Protection Primary     0/0        0/0        Ether
               730 eth1            Error       Error      No Protection Primary     0/0        0/0        Ether
               732 fc0             Up          Active     No Protection Unprotected 0/0        0/0        Fc
              8924                 Up          Active     No Protection Unprotected 0/0        0/0        Ether
    Fabric ID: B
               729 eth0            Error       Error      No Protection Backup      0/0        0/0        Ether
               731 eth1            Error       Error      No Protection Backup      0/0        0/0        Ether
               733 fc1             Error       Error      No Protection Unprotected 0/0        0/0        Fc
              8925                 Error       Error      No Protection Unprotected 0/0        0/0        Ether
N6K-FI1-B# show service-profile circuit server 1/2
Service Profile: esx1_2
Server: 1/2
    Fabric ID: A
               699 eth0            Error       Error      No Protection Primary     0/0        0/0        Ether
               701 eth1            Error       Error      No Protection Primary     0/0        0/0        Ether
               703 fc0             Up          Active     No Protection Unprotected 0/0        0/10       Fc
              8895                 Up          Active     No Protection Unprotected 0/0        0/0        Ether
    Fabric ID: B
               700 eth0            Error       Error      No Protection Backup      0/0        0/0        Ether
               702 eth1            Error       Error      No Protection Backup      0/0        0/0        Ether
               704 fc1             Error       Error      No Protection Unprotected 0/0        0/0        Fc
              8896                 Error       Error      No Protection Unprotected 0/0        0/0        Ether
N6K-FI1-B# show service-profile circuit server 2/1
Service Profile: esx2_1
Server: 2/1
    Fabric ID: A
               705 eth0            Error       Error      No Protection Primary     0/0        0/0        Ether
               707 eth1            Error       Error      No Protection Primary     0/0        0/0        Ether
               709 fc0             Up          Active     No Protection Unprotected 0/0        0/10       Fc
              8901                 Up          Active     No Protection Unprotected 0/0        0/0        Ether
    Fabric ID: B
               706 eth0            Error       Error      No Protection Backup      0/0        0/0        Ether
               708 eth1            Error       Error      No Protection Backup      0/0        0/0        Ether
               710 fc1             Error       Error      No Protection Unprotected 0/0        0/0        Fc
              8902                 Error       Error      No Protection Unprotected 0/0        0/0        Ether
N6K-FI1-B# show service-profile circuit server 2/2
Service Profile: esx2_2
Server: 2/2
    Fabric ID: A
               711 eth0            Error       Error      No Protection Primary     0/0        0/0        Ether
               713 eth1            Error       Error      No Protection Primary     0/0        0/0        Ether
               715 fc0             Up          Active     No Protection Unprotected 0/0        0/10       Fc
              8907                 Up          Active     No Protection Unprotected 0/0        0/0        Ether
    Fabric ID: B
               712 eth0            Error       Error      No Protection Backup      0/0        0/0        Ether
               714 eth1            Error       Error      No Protection Backup      0/0        0/0        Ether
               716 fc1             Error       Error      No Protection Unprotected 0/0        0/0        Fc
              8908                 Error       Error      No Protection Unprotected 0/0        0/0        Ether
N6K-FI1-B#
N6K-FI1-B(nxos)# show npv flogi-table
No flogi sessions found.
N6K-FI1-B(nxos)#
vsan database
  vsan 1020 interface vfc704
  vsan 1020 interface vfc710
  vsan 1020 interface vfc716
  vsan 1020 interface vfc722
  vsan 1020 interface vfc733
interface Ethernet1/5
  description U: Uplink
  pinning border
  switchport trunk allowed vlan 1-3
  channel-group 21 mode active
  no shutdown
N6K-FI1-B(nxos)# sh int vfc 704
vfc704 is down (Bound Physical Interface Down)
    Bound interface is Vethernet8896
    Port description is server 1/2, VHBA fc1
    Hardware is Virtual Fibre Channel
    Port WWN is 22:bf:54:7f:ee:c0:73:ff
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port vsan is 1020
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      0 frames input, 0 bytes
        0 discards, 0 errors
      0 frames output, 0 bytes
    last clearing of "show interface" counters never
N6K-FI1-B(nxos)# sh int vfc 716
vfc716 is down (Bound Physical Interface Down)
    Bound interface is Vethernet8908
    Port description is server 2/2, VHBA fc1
    Port WWN is 22:cb:54:7f:ee:c0:73:ff
    Port vsan is 1020
N6K-FI1-B(nxos)# sh int vfc 710
vfc710 is down (Bound Physical Interface Down)
    Bound interface is Vethernet8902
    Port description is server 2/1, VHBA fc1
    Port WWN is 22:c5:54:7f:ee:c0:73:ff
    Port vsan is 1020
N6K-FI1-B(nxos)# sh int vfc 733
vfc733 is down (Bound Physical Interface Down)
    Bound interface is Vethernet8925
    Port description is server 1/1, VHBA fc1
    Port WWN is 22:dc:54:7f:ee:c0:73:ff
    Port vsan is 1020
N6K-FI1-B(nxos)# sh int vfc 722
vfc722 is trunking (Not all VSANs UP on the trunk)
    Bound interface is port-channel20
    Port WWN is 22:d1:54:7f:ee:c0:73:ff
    Admin port mode is NP, trunk mode is on
    Port mode is TNP
    Port vsan is 1020
    Trunk vsans (admin allowed and active) (1,1020)
    Trunk vsans (up)                       (1020)
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             (1)
      165 frames input, 73020 bytes
      150 frames output, 17404 bytes
    Interface last changed at Tue Mar 26 00:20:40 2013
N6K-FI1-B(nxos)#
Thanks once again.
Since all vNIC / vHBA of all servers are in down state for Fabric B, can you verify the whether the links between FI B and IOM are up and active ?
Padma
Hi Padma,
Yes, I can confirm that the links between FI-B and IOM are all up and active.
Not really sure what the issue is here as the configs is the same on both FIs and N5Ks.
Is there any other area I need to check please?
FI and IOM model ?
Number of links between FI and IOM
From FI B NX-OS
sh int bri
show int veth 8925
Padma
FI - 6248
IOM - 2204
Number of links between FI and IOM - 1 uplink from each IOM to each FI
N6K-FI1-B(nxos)# sh int bri
Ethernet      VLAN   Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth1/1        1      eth  fabric up      none                        10G(D) --
Eth1/2        1      eth  fabric up      none                        10G(D) --
Eth1/3        1      eth  trunk  up      none                        10G(D) 21
Eth1/4        1      eth  access down    SFP not inserted            10G(D) --
Eth1/5        1      eth  trunk  down    Link not connected          10G(D) 21
Eth1/6        1      eth  access down    SFP not inserted            10G(D) --
Eth1/7        1      eth  access down    SFP not inserted            10G(D) --
Eth1/8        1      eth  access down    SFP not inserted            10G(D) --
Eth1/9        1      eth  access down    SFP not inserted            10G(D) --
Eth1/10       1      eth  access down    SFP not inserted            10G(D) --
Eth1/11       1      eth  access down    SFP not inserted            10G(D) --
Eth1/12       1      eth  access down    SFP not inserted            10G(D) --
Eth1/13       1      eth  access down    SFP not inserted            10G(D) --
Eth1/14       1      eth  access down    SFP not inserted            10G(D) --
Eth1/15       1      eth  access down    SFP not inserted            10G(D) --
Eth1/16       1      eth  access down    SFP not inserted            10G(D) --
Eth1/17       4049   eth  trunk  up      none                        10G(D) 20
Eth1/18       4049   eth  trunk  up      none                        10G(D) 20
Eth1/19       1      eth  access down    SFP not inserted            10G(D) --
Eth1/20       1      eth  access down    SFP not inserted            10G(D) --
Eth1/21       1      eth  access down    SFP not inserted            10G(D) --
Eth1/22       1      eth  access down    SFP not inserted            10G(D) --
Eth1/23       1      eth  access down    SFP not inserted            10G(D) --
Eth1/24       1      eth  access down    SFP not inserted            10G(D) --
Eth1/25       1      eth  access down    SFP not inserted            10G(D) --
Eth1/26       1      eth  access down    SFP not inserted            10G(D) --
Eth1/27       1      eth  access down    SFP not inserted            10G(D) --
Eth1/28       1      eth  access down    SFP not inserted            10G(D) --
Eth1/29       1      eth  access down    SFP not inserted            10G(D) --
Eth1/30       1      eth  access down    SFP not inserted            10G(D) --
Eth1/31       1      eth  access down    SFP not inserted            10G(D) --
Eth1/32       1      eth  access down    SFP not inserted            10G(D) --
Port-channel VLAN  Type Mode   Status  Reason                    Speed  Protocol
Interface
Po20         4049  eth  trunk  up      none                       a-10G(D)  lacp
Po21         1     eth  trunk  up      none                       a-10G(D)  lacp
Po1283       1     eth  vntag  up      none                       a-10G(D)  none
Po1285       1     eth  vntag  up      none                       a-10G(D)  none
Po1286       1     eth  vntag  up      none                       a-10G(D)  none
Po1287       1     eth  vntag  up      none                       a-10G(D)  none
Port   VRF          Status IP Address                              Speed    MTU
mgmt0  --           down   10.167.11.233                           100      1500
Vethernet     VLAN   Type Mode   Status  Reason                   Speed
Veth700       1      eth  trunk  down    nonPartcipating            auto
Veth702       1      eth  trunk  down    nonPartcipating            auto
Veth706       1      eth  trunk  down    nonPartcipating            auto
Veth708       1      eth  trunk  down    nonPartcipating            auto
Veth712       1      eth  trunk  down    nonPartcipating            auto
Veth714       1      eth  trunk  down    nonPartcipating            auto
Veth729       1      eth  trunk  down    nonPartcipating            auto
Veth731       1      eth  trunk  down    nonPartcipating            auto
Veth8896      1020   eth  access down    nonPartcipating            auto
Veth8902      1020   eth  access down    nonPartcipating            auto
Veth8908      1020   eth  access down    nonPartcipating            auto
Veth8925      1020   eth  access down    nonPartcipating            auto
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
vfc704     1020   F      on      BoundIfDown      --     --           --
vfc710     1020   F      on      BoundIfDown      --     --           --
vfc716     1020   F      on      BoundIfDown      --     --           --
vfc722     1020   NP     on      trunking         --     TNP     auto --
vfc733     1020   F      on      BoundIfDown      --     --           --
Interface        Ch #
Eth1/1/1      1      eth  vntag  up      none                        10G(D) 1286
Eth1/1/2      1      eth  vntag  up      none                        10G(D) 1286
Eth1/1/3      1      eth  vntag  up      none                        10G(D) 1286
Eth1/1/4      1      eth  vntag  up      none                        10G(D) 1286
Eth1/1/5      1      eth  vntag  up      none                        10G(D) 1287
Eth1/1/6      1      eth  vntag  up      none                        10G(D) 1287
Eth1/1/7      1      eth  vntag  up      none                        10G(D) 1287
Eth1/1/8      1      eth  vntag  up      none                        10G(D) 1287
Eth1/1/9      1      eth  access down    Administratively down       10G(D) --
Eth1/1/10     1      eth  access down    Administratively down       10G(D) --
Eth1/1/11     1      eth  access down    Administratively down       10G(D) --
Eth1/1/12     1      eth  access down    Administratively down       10G(D) --
Eth1/1/13     1      eth  access down    Administratively down       10G(D) --
Eth1/1/14     1      eth  access down    Administratively down       10G(D) --
Eth1/1/15     1      eth  access down    Administratively down       10G(D) --
Eth1/1/16     1      eth  access down    Administratively down       10G(D) --
Eth1/1/17     1      eth  access down    Administratively down       10G(D) --
Eth1/1/18     1      eth  access down    Administratively down       10G(D) --
Eth1/1/19     1      eth  access down    Administratively down       10G(D) --
Eth1/1/20     1      eth  access down    Administratively down       10G(D) --
Eth1/1/21     1      eth  access down    Administratively down       10G(D) --
Eth1/1/22     1      eth  access down    Administratively down       10G(D) --
Eth1/1/23     1      eth  access down    Administratively down       10G(D) --
Eth1/1/24     1      eth  access down    Administratively down       10G(D) --
Eth1/1/25     1      eth  access down    Administratively down       10G(D) --
Eth1/1/26     1      eth  access down    Administratively down       10G(D) --
Eth1/1/27     1      eth  access down    Administratively down       10G(D) --
Eth1/1/28     1      eth  access down    Administratively down       10G(D) --
Eth1/1/29     1      eth  access down    Administratively down       10G(D) --
Eth1/1/30     1      eth  access down    Administratively down       10G(D) --
Eth1/1/31     1      eth  access down    Administratively down       10G(D) --
Eth1/1/32     1      eth  access down    Administratively down       10G(D) --
Eth1/1/33     4044   eth  trunk  up      none                       1000(D) --
Eth2/1/1      1      eth  vntag  up      none                        10G(D) 1283
Eth2/1/2      1      eth  vntag  up      none                        10G(D) 1283
Eth2/1/3      1      eth  vntag  up      none                        10G(D) 1285
Eth2/1/4      1      eth  vntag  up      none                        10G(D) 1285
Eth2/1/5      1      eth  access down    Administratively down       10G(D) --
Eth2/1/6      1      eth  access down    Administratively down       10G(D) --
Eth2/1/7      1      eth  access down    Administratively down       10G(D) --
Eth2/1/8      1      eth  access down    Administratively down       10G(D) --
Eth2/1/9      1      eth  access down    Administratively down       10G(D) --
Eth2/1/10     1      eth  access down    Administratively down       10G(D) --
Eth2/1/11     1      eth  access down    Administratively down       10G(D) --
Eth2/1/12     1      eth  access down    Administratively down       10G(D) --
Eth2/1/13     1      eth  access down    Administratively down       10G(D) --
Eth2/1/14     1      eth  access down    Administratively down       10G(D) --
Eth2/1/15     1      eth  access down    Administratively down       10G(D) --
Eth2/1/16     1      eth  access down    Administratively down       10G(D) --
Eth2/1/17     4044   eth  trunk  up      none                       1000(D) --
N6K-FI1-B(nxos)#
N6K-FI1-B(nxos)# show int veth 8925
Vethernet8925 is down (nonPartcipating)
    Bound Interface is --
  Hardware: Virtual, address: 547f.eec0.73a0 (bia 547f.eec0.73a0)
  Description: server 1/1, VHBA fc1
  Encapsulation ARPA
  Port mode is access
  EtherType is 0x8100
  Rx
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 input packet drops
  Tx
    0 output packets  0 bytes
    0 flood packets
    0 output packet drops
N6K-FI1-B(nxos)#
Thank once again
Are these servers in production ?
If not, rebooting the server or dis-associating / re-associating service profile might resolve the issue. However, if you could collect UCSM and Chassis 1 tech support before making any changes so that we can figure out following state.
Please open TAC Service request for further investigation.
Padma
Hi Padma,
Can you please confirm what exact commands I need to collect the info prior to rebooting the servers?
The server are not yet in production but should be soon if I could resolve this issue.
Thanks very much for your help.
I will raise a TAC case as advised too.
Luke
The following guide includes screen shots on how to collect UCSM and Chassis tech support bundle.
http://www.cisco.com/en/US/products/ps10281/products_tech_note09186a0080bdf11c.shtml
