Cisco HX240c M5 HyperFlex Node Error Power supply
thait01
Frequent Visitor
Frequent Visitor
My power supply is showing amber. Please help me find a solution.
thait01
Frequent Visitor
Frequent Visitor
(view in My Videos)
Looks like that PSU fan is struggling to spin in the video.
I would:
  1. Collect CIMC logs.
  2. Physically reseat the bottom PSU.
  3. Check if fan is spinning/not-spinning after reseat.
  4. Collect CIMC logs.
  5. If fan is not spinning (or struggling to spin like that video shows), then open a TAC case for an RMA.
@thait01 , hi, you can login to the hx and confirm the alerts for power supply.
1. make sure your power source providing the power
2. try re-seat the power cable
if error continues, open a TAC Case. they will normally ask  to re-seat the power supply in server if there is no abnormal issues in logs or if there is any faulty indications in server, they advice next steps.
Good luck
KB
