06-18-2013 04:48 AM - edited 03-01-2019 11:05 AM
Can anyone help me to configure/troubleshoot Cisco MDS 9148 with Cisco USC ? M stuck in port channel..i have configured but interfaces are not coming UP.It is showing init state.
My Topology is like,
Nexus 5000-->USC FI (single FI) -->Cisco MDS 9148
--> Two Chassis
Any help would be highly appreciated...
Thanx
Solved! Go to Solution.
06-18-2013 02:05 PM
Hi Praveen,
It looks like you are hitting the following bug CSCty04686
Add MAC OUI "002a6a", "8c604f", "00defb" for 5k/UCS-FI
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCty04686
To fix this issue you will have to upgrade your MDS switch to the 5.28 release. The root cause of this issue is that the OUI id 002a6a is not present in the file system for the current version of software that your MDS is running.
06-18-2013 05:57 AM
Hello Praveen,
Please provide basic necessary info to help you out.
Is trunking enabled on FI ?
Does MDS 9148 supports f-port-channel ? If yes, have you enabled f-port-channel-trunk feature on it ?
Software version on MDS ?
Have you correctly configured the VSANs ?
Please share " show run int " output from both FI and MDS devices.
Padma
06-18-2013 01:30 PM
Hello Padramas,
Following are the commands configured on MDS:-
interface fc1/15
switchport rate-mode dedicated
port-license acquire
channel-group 2 force
no shutdown
interface fc1/16
no shutdown
fport-channel-trunk is enabled
kickstart image file is: bootflash:/m9100-s3ek9-kickstart-mz.5.0.1a.bin
kickstart compile time: 12/25/2020 12:00:00 [02/21/2010 20:09:44]
system image file is: bootflash:/m9100-s3ek9-mz.5.0.1a.bin
system compile time: 2/2/2010 17:00:00 [02/21/2010 23:13:41]
Following are the snap shot from UCS manager :-
06-18-2013 08:46 AM
Hi Praveen,
Have you tried bringing the individual interfaces up on the MDS and UCS?
Can you provide the mac adress of one of the interfaces on the fabric interconnect?
you can get this by runnin the following commands:
F_A# connect nxos
F_A(nxos)# show interface ethernet 1/1 | in Hardware
What software version is your MDS switch running?
06-18-2013 01:55 PM
Hi Manuel,
Yes MDS and UCS interfaces are UP.
when is run
F_A(nxos)# show interface ethernet 1/1 | in Hardware this command nothing comes.
TMC-UCSFI-A-A(nxos)# sh interface ethernet 1/1 mac-address
Interface Mac-Address Burn-in Mac-Address
Ethernet1/1 002a.6a27.be01 002a.6a27.bdc8
MDS is running :-
Thanx
06-18-2013 01:58 PM
TMC-UCSFI-A-A(nxos)# sh interface brief
Interface Vsan Admin Admin Status SFP Oper Oper Port
Mode Trunk Mode Speed Channel
Mode (Gbps)
fc1/31 1 NP off errDisabled swl -- --
fc1/32 1 NP off errDisabled swl -- --
Ethernet VLAN Type Mode Status Reason Speed Port
Interface Ch #
Eth1/1 1 eth fabric up none 10G(D) --
Eth1/2 1 eth fabric up none 10G(D) --
Eth1/3 1 eth fabric up none 10G(D) --
Eth1/4 1 eth fabric up none 10G(D) --
Eth1/5 1 eth access down SFP not inserted 10G(D) --
Eth1/6 1 eth access down SFP not inserted 10G(D) --
Eth1/7 1 eth access down SFP not inserted 10G(D) --
Eth1/8 1 eth access down SFP not inserted 10G(D) --
Eth1/9 1 eth access down SFP not inserted 10G(D) --
Eth1/10 1 eth access down SFP not inserted 10G(D) --
Eth1/11 1 eth access down SFP not inserted 10G(D) --
Eth1/12 1 eth access down SFP not inserted 10G(D) --
Eth1/13 1 eth access down SFP not inserted 10G(D) --
Eth1/14 1 eth access down SFP not inserted 10G(D) --
Eth1/15 1 eth trunk up none 10G(D) 100
Eth1/16 1 eth trunk up none 10G(D) 100
Eth1/17 1 eth fabric up none 10G(D) --
Eth1/18 1 eth fabric up none 10G(D) --
Eth1/19 1 eth fabric up none 10G(D) --
Eth1/20 1 eth fabric up none 10G(D) --
Eth1/21 1 eth access down SFP not inserted 10G(D) --
Eth1/22 1 eth access down SFP not inserted 10G(D) --
Eth1/23 1 eth access down SFP not inserted 10G(D) --
Eth1/24 1 eth access down SFP not inserted 10G(D) --
Eth1/25 1 eth access down SFP not inserted 10G(D) --
Eth1/26 1 eth access down SFP not inserted 10G(D) --
Eth1/27 1 eth access down SFP not inserted 10G(D) --
Eth1/28 1 eth access down SFP not inserted 10G(D) --
Eth1/29 1 eth access down SFP not inserted 10G(D) --
Eth1/30 1 eth access down SFP not inserted 10G(D) --
output ommitted
Here it shows that Fc1/31- 32 which are in trunk , status is errdisabled and admin trunk mode is off
06-18-2013 02:05 PM
Hi Praveen,
