Cisco Nexus 3500 IOS Upgradation
UniWAQ
Hi All ,
I want to update Cisco Nexus from   n3500-uk9.6.0.2.A4.4.bin to  n3500-uk9.6.0.2.A6.5a.bin , but am facing threshold error. Please guide me what are the possibilit for it. I have free space  but facing error.
# dir bootflash:///
          0    Jan 01 04:58:34 2011  20110101_095834_poap_3883_init.log
          0    Jul 23 05:23:24 2015  20150723_102324_poap_3806_init.log
         84    Aug 11 04:40:53 2015  20150811_094025_poap_3802_init.log
        625    Jul 23 05:01:05 2015  license_FOC1928R1P5_3_1.lic
   36759040    Aug 11 05:02:05 2015  n3500-uk9-kickstart.6.0.2.A4.4.bin
   36742656    Jul 23 04:52:15 2015  n3500-uk9-kickstart.6.0.2.A4.5.bin
   36825088    Jul 27 07:33:14 2016  n3500-uk9-kickstart.6.0.2.A6.5a.bin
  166885895    Aug 11 05:01:42 2015  n3500-uk9.6.0.2.A4.4.bin
  166878338    Jul 23 04:54:05 2015  n3500-uk9.6.0.2.A4.5.bin
  180349300    Jul 27 07:31:34 2016  n3500-uk9.6.0.2.A6.5a.bin
       4096    Jan 01 04:57:39 2011  vdc_2/
       4096    Jan 01 04:57:39 2011  vdc_3/
       4096    Jan 01 04:57:39 2011  vdc_4/
       4096    Jan 01 04:57:44 2011  virtual-instance-stby-sync/
Usage for bootflash://sup-local
  755032064 bytes used
1140137984 bytes free
1895170048 bytes total
#  show install all impact kickstart n3500-uk9-kickstart.6.0.2.A6.5a.bin                       system n3500-uk9.6.0.2.A6.5a.bin
Installer is forced disruptive
Pre-upgrade check failed. Return code 0x40930062 (free space in the filesystem i                     s below threshold).
ZUSW002# show s
snmp             sprom            switch-profile
sockets          ssh              switchname
spanning-tree    startup-config   system
# show system internal log install details | include space
<Wed Jul 27 07:37:58 2016> check_freespace: check_freespace: /var/sysmgr total b
locks: 230400, free blocks: 0, space being used: 100%
<Wed Jul 27 07:37:58 2016> fsm_action_pre_verification: fsm_action_pre_verificat
ion: Free space in "/var/sysmgr" partition is below threshold: 80
Walter Dey
I would open a TAC case ! most likely it requires the debug plugin.
Hello ,
  I have also faced similar issue.
Please let me know if something we can do it without TAC.
How did you resolve the issue.
Please reply...
Thank you,
Pradeep K
sontran68
I have the same issue with Nexcu 5596UP. Is there a colution for this yet?
