Cisco Nexus: Flogi Keep Flapping
Hi All,
My N5K going down yesterday and cannot bootup. We already replace the hardware with the new hardware.
But after changes, 1 of the solaris box san connectivity keep flapping. the log as below:
2017 May 23 16:59:46 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_OUT: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d logged OUT.
2017 May 23 16:59:46 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (waiting for flogi)  Solaris FCOE SAN Port
2017 May 23 16:59:48 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (Initializing)  Solaris FCOE SAN Port
2017 May 23 16:59:48 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_IN: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d with FCID 0x160120 log
ged IN.
2017 May 23 16:59:48 MBBKULSPJY100 %PORT-5-IF_TRUNK_UP: %$VSAN 10%$ Interface vfc21, vsan 10 is up  Solaris FCOE SAN Port
2017 May 23 17:02:45 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_OUT: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d logged OUT.
2017 May 23 17:02:45 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (waiting for flogi)  Solaris FCOE SAN Port
2017 May 23 17:02:48 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (Initializing)  Solaris FCOE SAN Port
2017 May 23 17:02:48 MBBKULSPJY100 %PORT-5-IF_TRUNK_UP: %$VSAN 10%$ Interface vfc21, vsan 10 is up  Solaris FCOE SAN Port
2017 May 23 17:02:48 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_IN: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d with FCID 0x160120 log
ged IN.
2017 May 23 17:03:08 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_OUT: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d logged OUT.
2017 May 23 17:03:08 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (waiting for flogi)  Solaris FCOE SAN Port
2017 May 23 17:03:18 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (Initializing)  Solaris FCOE SAN Port
2017 May 23 17:03:18 MBBKULSPJY100 %PORT-5-IF_TRUNK_UP: %$VSAN 10%$ Interface vfc21, vsan 10 is up  Solaris FCOE SAN Port
2017 May 23 17:03:18 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_IN: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d with FCID 0x160120 log
ged IN.
2017 May 23 17:06:39 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_OUT: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d logged OUT.
2017 May 23 17:06:39 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (waiting for flogi)  Solaris FCOE SAN Port
2017 May 23 17:06:48 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (Initializing)  Solaris FCOE SAN Port
2017 May 23 17:06:48 MBBKULSPJY100 %PORT-5-IF_TRUNK_UP: %$VSAN 10%$ Interface vfc21, vsan 10 is up  Solaris FCOE SAN Port
2017 May 23 17:06:48 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_IN: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d with FCID 0x160120 log
ged IN.
2017 May 23 17:09:37 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_OUT: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d logged OUT.
2017 May 23 17:09:37 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (waiting for flogi)  Solaris FCOE SAN Port
2017 May 23 17:09:48 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (Initializing)  Solaris FCOE SAN Port
2017 May 23 17:09:48 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_IN: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d with FCID 0x160120 log
ged IN.
2017 May 23 17:09:48 MBBKULSPJY100 %PORT-5-IF_TRUNK_UP: %$VSAN 10%$ Interface vfc21, vsan 10 is up  Solaris FCOE SAN Port
2017 May 23 17:10:40 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_OUT: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d logged OUT.
2017 May 23 17:10:40 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (waiting for flogi)  Solaris FCOE SAN Port
2017 May 23 17:10:48 MBBKULSPJY100 %PORT-5-IF_TRUNK_DOWN: %$VSAN 10%$ Interface vfc21, vsan 10 is down (Initializing)  Solaris FCOE SAN Port
2017 May 23 17:10:48 MBBKULSPJY100 %FLOGI-5-MSG_PORT_LOGGED_IN: %$VSAN 10%$ [VSAN 10, Interface vfc21: mode[TF]] Nx Port 21:00:00:c0:dd:1a:0d:1d with FCID 0x160120 log
ged IN.
2017 May 23 17:10:48 MBBKULSPJY100 %PORT-5-IF_TRUNK_UP: %$VSAN 10%$ Interface vfc21, vsan 10 is up  Solaris FCOE SAN Port
Any idea on how to find any issue with N5K.
N5K using is C5596UP with NXOS 6.0(2)N2(3)
Walter Dey
Hi Ismail
Questions:
- did you restore the configuration ?
- are you using classical FC or FCoE ?
- is the Solaris connecting with classical FC ?
- do you have other Solaris hosts that are working ?
- can you post a layout of the network ? is this UCS based ?
- strange ? why is this a trunk port ? don't think that Solaris can handle a trunk port ?
Questions:
# yes
#FCOE
# Nope, connected using FCOE
# Yes
# Dont have the layout currently. Not UCS based.
# Its proven working.
The issue already resolve by change the SFP. The strange thing, no error on the physical. Just give a try by changing the SFP and the flapping gone.
