Cisco UCS B200 M4 System Board Replacement procedure
rogerfreitas
We need to replace a System Board on a Cisco UCS B200 M4 part 73-15862-04.
Wondering were could I find a replacement procedure steps as the Cisco UCS B200 M4 Blade Server Installation and Service Note does not have that.
Roger
Kirk J
When TAC replaces a 'system board' it is a base B200 M4 with no DIMMs, CPUs, SAS controller, VIC card,  disks, sdcard, etc,etc
Your instructions would basically be transferring the CPUs, DIMMs, and so on to the replacement bare b200 m4 chassis.
Service guide, which you obviously already found, is at https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/hw/blade-servers/B200M4/B200M4_chapter_011.html
You may need heatsink cleaner, and thermal grease to reseat the CPUs&heatsinks in new systemboard.
Kirk...
Kirk J
Kirk...
Thanks.
Roger
