Cisco UCS C22 M3 FAN SPEED
raul_medina
I have a server Cisco UCS C22 M3 in which the fan speed not lower than 6000 RPM and generates a lot of noise. It is normal from turning on the computer and put at that speed?
thanks
greetings
11 Replies 11
padramas
Hello Raul,
Can you share output of following command
show version
connect debug-shell
sensors
How about the ambient temperature in the server room ?
Padma
Thanks for the reply.
ucs-c22-m3# show version
Firmware Version
1.4(7a)
ucs-c22-m3# connect debug-shell
CIMC Debug Firmware Utility Shell [ cli ]
[ help ]# sensors
Sensor Name      | Reading    | Unit       | Status| LNR       | LC        | LNC       | UNC       | UC        | UNR
PS_RDNDNT_MODE   | na         | discrete   | na    | na        | na        | na        | na        | na        | na
BIOS_POST_CMPLT  | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
FP_ID_LED        | 0x0        | discrete   | 0x4180| na        | na        | na        | na        | na        | na
P_CATERR_N       | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
MAIN_POWER_PRS   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
SEL_FULLNESS     | 100.000    | unspecified | nr    | na        | na        | na        | 80.000    | 90.000    | 99.000
BIOSPOST_TIMEOUT | na         | discrete   | na    | na        | na        | na        | na        | na        | na
POWER_ON_FAIL    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
PCH_THERMTRIP    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN1_PRSNT       | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
FAN2_PRSNT       | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
FAN3_PRSNT       | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
FAN4_PRSNT       | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
FAN5_PRSNT       | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P1_THERMTRIP_N   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
P2_THERMTRIP_N   | na         | discrete   | na    | na        | na        | na        | na        | na        | na
FAN1_TACH1       | 6800.000   | RPM        | ok    | 800.000   | 1200.000  | 1600.000  | na        | na        | na
FAN1_TACH2       | 7000.000   | RPM        | ok    | 800.000   | 1200.000  | 1600.000  | na        | na        | na
FAN2_TACH1       | 6800.000   | RPM        | ok    | 800.000   | 1200.000  | 1600.000  | na        | na        | na
FAN2_TACH2       | 7000.000   | RPM        | ok    | 800.000   | 1200.000  | 1600.000  | na        | na        | na
FM_TPM_CARD_PRS  | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
RISER2_PRESENT   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
RISER1_PRESENT   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
RISER2_PRESENT_2 | na         | discrete   | na    | na        | na        | na        | na        | na        | na
RISER2_PRESENT_3 | na         | discrete   | na    | na        | na        | na        | na        | na        | na
RISER1_PRESENT_2 | na         | discrete   | na    | na        | na        | na        | na        | na        | na
RISER2_PRESENT_1 | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
RISER1_PRESENT_1 | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
PSU1_STATUS      | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
PSU2_STATUS      | na         | discrete   | na    | na        | na        | na        | na        | na        | na
P1_PROCHOT       | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
P2_PROCHOT       | na         | discrete   | na    | na        | na        | na        | na        | na        | na
PVCCD_P1_VRHOT   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
PVCCP_P1_VRHOT   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
PVCCD_P2_VRHOT   | na         | discrete   | na    | na        | na        | na        | na        | na        | na
PVCCP_P2_VRHOT   | na         | discrete   | na    | na        | na        | na        | na        | na        | na
PSU1_PWRGD       | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
PSU1_AC_OK       | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
PSU2_PWRGD       | na         | discrete   | na    | na        | na        | na        | na        | na        | na
PSU2_AC_OK       | na         | discrete   | na    | na        | na        | na        | na        | na        | na
P1_MEM23_MEMHOT  | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
P1_MEM01_MEMHOT  | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
P2_MEM23_MEMHOT  | na         | discrete   | na    | na        | na        | na        | na        | na        | na
P2_MEM01_MEMHOT  | na         | discrete   | na    | na        | na        | na        | na        | na        | na
P1_PRESENT       | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P2_PRESENT       | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
P1_TEMP_SENS     | 40.500     | degrees C  | ok    | na        | na        | na        | 87.000    | 92.000    | 97.000
P2_TEMP_SENS     | na         | degrees C  | na    | na        | na        | na        | 62.000    | 72.000    | 82.000
LED_PSU_STATUS   | 0x0        | discrete   | 0x1280| na        | na        | na        | na        | na        | na
LED_TEMP_STATUS  | 0x0        | discrete   | 0x1280| na        | na        | na        | na        | na        | na
LED_FAN_STATUS   | 0x0        | discrete   | 0x1280| na        | na        | na        | na        | na        | na
LED_HLTH_STATUS  | 0x0        | discrete   | 0x1280| na        | na        | na        | na        | na        | na
FP_TEMP_SENSOR   | 28.000     | degrees C  | ok    | na        | na        | na        | 65.000    | 75.000    | 85.000
HDD1_STATUS      | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
HDD2_STATUS      | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
HDD3_STATUS      | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
HDD4_STATUS      | 0x0        | discrete   | 0x0080| na        | na        | na        | na        | na        | na
HDD5_STATUS      | 0x0        | discrete   | 0x0080| na        | na        | na        | na        | na        | na
HDD6_STATUS      | 0x0        | discrete   | 0x0080| na        | na        | na        | na        | na        | na
HDD7_STATUS      | 0x0        | discrete   | 0x0080| na        | na        | na        | na        | na        | na
HDD8_STATUS      | 0x0        | discrete   | 0x0080| na        | na        | na        | na        | na        | na
HDD9_STATUS      | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD10_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD11_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD12_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD13_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD14_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD15_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD16_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD17_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD18_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD19_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD20_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD21_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD22_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD23_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
HDD24_STATUS     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
DDR3_P1_A1_PRS   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
DDR3_P1_A1_TEMP  | 25.000     | degrees C  | ok    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P1_A2_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P1_A2_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P1_B1_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P1_B1_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P1_B2_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P1_B2_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P1_C1_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P1_C1_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P1_C2_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P1_C2_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P2_D1_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P2_D1_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P2_D2_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P2_D2_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P2_E1_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P2_E1_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P2_E2_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P2_E2_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P2_F1_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P2_F1_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
DDR3_P2_F2_PRS   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
DDR3_P2_F2_TEMP  | na         | degrees C  | na    | na        | na        | na        | 68.000    | 70.000    | 85.000
POWER_USAGE      | 64.000     | Watts      | ok    | na        | na        | na        | na        | 1400.000  | 1552.000
VICP81E_0_PRS    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
VICP81E_0_OVRTMP | na         | discrete   | na    | na        | na        | na        | na        | na        | na
VICP81E_0_TMP1   | na         | degrees C  | na    | na        | na        | na        | 65.000    | 70.000    | 75.000
VICP81E_0_TMP2   | na         | degrees C  | na    | na        | na        | na        | 65.000    | 70.000    | 75.000
VICP81E_0_TMP3   | na         | degrees C  | na    | na        | na        | na        | 65.000    | 70.000    | 75.000
DDR3_P1_A1_ECC   | 0.000      | error      | ok    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P1_A2_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P1_B1_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P1_B2_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P1_C1_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P1_C2_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P2_D1_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P2_D2_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P2_E1_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P2_E2_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P2_F1_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
DDR3_P2_F2_ECC   | na         | error      | na    | na        | na        | na        | na        | 10.000    | 15.000
P3V_BAT_SCALED   | 3.192      | Volts      | ok    | 2.181     | 2.514     | na        | na        | 3.325     | na
P1V1_PBG         | 1.067      | Volts      | ok    | 0.999     | 1.018     | na        | na        | 1.183     | 1.213
VDDQ_ABC_SCALED  | 1.465      | Volts      | ok    | 1.348     | 1.407     | na        | na        | 1.610     | 1.649
CPU1_VCORE       | 0.737      | Volts      | ok    | 0.563     | 0.582     | na        | na        | 1.251     | 1.271
P5VAUX_SCALED    | 4.941      | Volts      | ok    | 4.507     | 4.651     | na        | na        | 5.350     | 5.495
P3V3_SCALED      | 3.239      | Volts      | ok    | 2.970     | 3.065     | na        | na        | 3.539     | 3.634
P5V_SCALED       | 4.965      | Volts      | ok    | 4.507     | 4.651     | na        | na        | 5.350     | 5.495
P12V-4_SCALED    | 11.682     | Volts      | ok    | 10.561    | 10.797    | na        | na        | 13.216    | 13.452
CPU2_VCORE       | na         | Volts      | na    | 0.563     | 0.582     | na        | na        | 1.251     | 1.271
P12V-1_SCALED    | 11.682     | Volts      | ok    | 10.561    | 10.797    | na        | na        | 13.216    | 13.452
P12V-2_SCALED    | 11.741     | Volts      | ok    | 10.561    | 10.797    | na        | na        | 13.216    | 13.452
P12V-3_SCALED    | 11.741     | Volts      | ok    | 10.561    | 10.797    | na        | na        | 13.216    | 13.452
VDDQ_DEF_SCALED  | na         | Volts      | na    | 1.348     | 1.407     | na        | na        | 1.610     | 1.649
P12VAUX_SCALED   | 11.682     | Volts      | ok    | 10.561    | 10.797    | na        | na        | 13.216    | 13.452
P3V3AUX_SCALED   | 3.271      | Volts      | ok    | 2.970     | 3.065     | na        | na        | 3.539     | 3.634
P1V8AUX_SCALED   | 1.698      | Volts      | ok    | 1.620     | 1.678     | na        | na        | 1.930     | 1.979
PSU1_VOUT        | 11.000     | Volts      | ok    | na        | na        | na        | na        | 247.000   | 255.000
MLOM_PRESENT     | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
MLOM_TEMP_SENS   | na         | degrees C  | na    | na        | na        | na        | 65.000    | 74.000    | 79.000
AMBIENT1_TEMP    | 34.000     | degrees C  | ok    | na        | na        | na        | 65.000    | 75.000    | 85.000
AMBIENT2_TEMP    | 36.000     | degrees C  | ok    | na        | na        | na        | 65.000    | 75.000    | 85.000
PSU1_IOUT        | 3.776      | Amps       | ok    | na        | na        | na        | 56.640    | 58.292    | 60.180
PSU1_POUT        | 40.000     | Watts      | ok    | na        | na        | na        | 1100.000  | 1180.000  | 1275.000
PSU2_VOUT        | na         | Volts      | na    | na        | na        | na        | na        | 247.000   | 255.000
PSU2_IOUT        | na         | Amps       | na    | na        | na        | na        | 56.640    | 58.292    | 60.180
PSU2_POUT        | na         | Watts      | na    | na        | na        | na        | 1100.000  | 1180.000  | 1275.000
FAN3_TACH1       | 6800.000   | RPM        | ok    | 800.000   | 1200.000  | 1600.000  | na        | na        | na
FAN3_TACH2       | 7000.000   | RPM        | ok    | 800.000   | 1200.000  | 1600.000  | na        | na        | na
FAN4_TACH1       | 6800.000   | RPM        | ok    | 800.000   | 1200.000  | 1600.000  | na        | na        | na
FAN4_TACH2       | 7000.000   | RPM        | ok    | 800.000   | 1200.000  | 1600.000  | na        | na        | na
FAN5_TACH1       | 6800.000   | RPM        | ok    | 800.000   | 1200.000  | 1600.000  | na        | na        | na
FAN5_TACH2       | 7200.000   | RPM        | ok    | 800.000   | 1200.000  | 1600.000  | na        | na        | na
PCH_TEMP_SENS    | 44.000     | degrees C  | ok    | na        | na        | na        | 80.000    | 85.000    | 90.000
PSU1_TEMP        | 31.000     | degrees C  | ok    | na        | na        | na        | 60.000    | 65.000    | 70.000
PSU2_TEMP        | na         | degrees C  | na    | na        | na        | na        | 60.000    | 65.000    | 70.000
PSU1_PIN         | 65.000     | Watts      | ok    | na        | na        | na        | 1100.000  | 1180.000  | 1275.000
PSU2_PIN         | na         | Watts      | na    | na        | na        | na        | 1100.000  | 1180.000  | 1275.000
P1_LVC3_PWRGD    | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P2_LVC3_PWRGD    | na         | discrete   | na    | na        | na        | na        | na        | na        | na
P1V1_AUX_PWRGD   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P3V3_AUX_PWRGD   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P1V5_PBG_PWRGD   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P1V1_PBG_PWRGD   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P1_VTT_PWRGD     | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P2_VTT_PWRGD     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
DDR_ABC_PWRGD    | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
DDR_DEF_PWRGD    | na         | discrete   | na    | na        | na        | na        | na        | na        | na
P1_PLL_PWRGD     | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P2_PLL_PWRGD     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
DRAM_PWRGD       | na         | discrete   | na    | na        | na        | na        | na        | na        | na
P1_VCORE_PWRGD   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P2_VCORE_PWRGD   | na         | discrete   | na    | na        | na        | na        | na        | na        | na
P1V8_AUX_PWRGD   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
P1V5_AUX_PWRGD   | 0x0        | discrete   | 0x0280| na        | na        | na        | na        | na        | na
LED_FAN1_FAULT   | 0x0        | discrete   | 0x2180| na        | na        | na        | na        | na        | na
LED_FAN2_FAULT   | 0x0        | discrete   | 0x2180| na        | na        | na        | na        | na        | na
LED_FAN3_FAULT   | 0x0        | discrete   | 0x2180| na        | na        | na        | na        | na        | na
LED_FAN4_FAULT   | 0x0        | discrete   | 0x2180| na        | na        | na        | na        | na        | na
LED_FAN5_FAULT   | 0x0        | discrete   | 0x2180| na        | na        | na        | na        | na        | na
LEGEND:
LNR: Lower Non Recoverable Threshold
LC : Lower Critical Threshold
LNC: Lower Non Critical Threshold
UNC: Upper Non Critical Threshold
UC : Upper Critical Threshold
UNR: Upper Non Recoverable Threshold
Hello Raul,
Looks like temperature is not an issue and we need additional logs to investigate why FANs are running at high speed.
I would suggest you to open a TAC service request with CIMC tech support bundle.
Padma
Thanks a lot
Raul
One thing, above the small fans inside there like a plastic cover, it may be that the problem?
greetings
Hello Raul,
It might not be an issue.
Have you recently rebooted the server ?
Do you have OS running on this server ?
Did it get stuck without completing OS boot sequence ?
You can add above information or open TAC service request from this thread.
Padma
When I restart the server starts at 11,000 revolutions. 2 minutes then dropped to 3500 rpm and 5 min at 6000 rpm then rises and hence no low.
I have installed Windows Server 2008 R2 Enterprise on a RAID 5 consisting of 3 hard drives Cisco 10000.
The system is fully installed and not yet in production.
When I reset the CIMC low at 3000 RPM for 3 minutes and goes up to 6000.
Thanks for the help.
Hello Raul,
Is this new server ?
When did the problem start ?
Does it boot Windows without getting stuck in BIOS / EFI screen ?
Padma
The server has four months and the problem is from the beginning. Gives no problem when it starts. May be problem of RAID 5 configuration?
Do not know how to try to keep the system.
thanks
greetings
Hello Raul, This might not be an issue as it could be color-coded touch point. Server has color-coded touch points that indicate thumbscrews and latches on replaceable and hot-swappable components.
• Hot-swappable components have green plastic touch points. This includes the power supplies. (Exceptions are the drive trays on the front panel, which are hot-swappable but not green).
• Some replaceable but non-hot-swappable components have light-blue plastic touch-points.
Please refer
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/hw/C22/install/C22.pdf
walter baziuk
Level 5
Level 5
hello
we have muliple Vblock (www.vce.com)  ie UCS systems with multipl UCS chassis and storage
around 25% of our UCS B blades servers have the same sympotoms, we are in production  and our SE does not know what the issue is.
just as you explained, we see the same symtoms, the blades start up slow, go high, drop down again and then some go back up to high speed.
server load is not related to the ones that go high speed
all blades have the fw releases
any else have this symptom
it is very anoying
