Cisco UCS Components, how to find temperature thresholds?
Adrian Sutton
How do I find the temperature thresholds of components within a Cisco UCS environment?
For example we have 4 Fabric Interconnects and 2 run at approx 42 degrees Celsius on the motherboard while 2 run at around 48 degrees Celsius.  I would like to know the Upper Thresholds when alerting would start.
I found the following post which shows server thresholds but not sure how to fine for the Fabric Interconnects or other components
UCS CPU temperature thresholds | Unified Computing | Cisco Technical Support Forum | 6011 | 11621236
Is there any documentation which shows all the default settings for temperature thresholds of all components
Many Thanks
Adrian
Adrian Sutton
The command is
show environment from nxos cli
On a Fabric Interconnect use ssh to FI A or B
connect nxos
show environment
This will display temperature of FI's and ranges for alerts
Adrian Sutton
The command is
connect nxos
show environment
what is A and B here ?
