Cisco UCS Firmware Upgrade problem
Przemyslaw
Hello
Cisco UCS 5108
Fabric Interconector Cisco UCS 6248UP
I have a problem with Cisco UCS Firmware Upgrade 2.2 (8i) to 3.1 or3.2
During the upgrade process (95%) an error occurs (remote invocation error code 1001)
Kirk J
Greetings.
Make sure all your hardware is supported in 3.1 (no 6100 FIs, M81KR adapters, M1 servers, certain M2 servers) as that is a hanging point I believe if you have unsupported hardware.
There are a number of internal logs that would make it clear what the exact problem is, but would need to see logs.
Probably best to open a TAC case if you are certain you aren't running deprecated hardware (see https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/CiscoUCSManager-RN-3-1.html#reference_D8E0F1697DB8476D8B3016D38ECB6E72 )
Kirk...
