Cisco UCS m6 chassis
Udayv_TCS
Hi All,
Can we configure the latest Cisco M6 models by the UCS manager?
Brian Morrissey
Depends on the device, the x210c m6 for example can only be managed via Intersight whereas the B200 M6 or C220 M6 can be managed by either Intersight or Ucsm.
The spec sheet for the server in question should have further details on the available management modes
Thanks for your response.
do you have any link to check this compatibility module?
I haven't seen a matrix, I would just doublecheck the datasheet or spec sheets for the specific server you are interested in.
For example B200 M6 (Search for Management mode) - https://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/datasheet-c78-2368888.html
Management
Cisco Intersight software
Cisco UCS Manager Release 4.2(1)
Cisco UCS Central Software
Cisco UCS Director
Cisco UCS Performance Manager
Or X210c M6 (Search for Management) - https://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-x-series-modular-system/datasheet-c78-2465523.html
Management
Cisco Intersight software (SaaS, virtual appliance, and private virtual appliance)
