06-27-2015 12:44 PM - edited 03-01-2019 12:15 PM
i am using Cisco UCS Platform Emulator™ Control Panel 3.0 once i try to add new chasis or copy existing chasis getting below error could you provide me solution
Exceed max chassis number(1)
Solved! Go to Solution.
06-27-2015 01:09 PM
Hey Moazzam,
thanks for posting your query.
3.0 --> https://communities.cisco.com/docs/DOC-53980
Cisco UCS PE 3.0 only supports the 6324 Fabric Interconnect based domains. No other Fabric Interconnect (6100 / 6200) will work with this UCSPE.
The release supports having only 1 chassis and 4 rack servers as of now. Hence the user cannot configure more than 1 chassis.
If you would want to use 6100 / 6200 Fabric Interconnects or multiple chassis, you can download Cisco UCS Platform Emulator (2.2(2cPE1)) --> https://communities.cisco.com/docs/DOC-52943
Please read for more information-- https://communities.cisco.com/docs/DOC-37827
Saurabh
06-27-2015 01:09 PM
Hey Moazzam,
Saurabh
06-27-2015 01:50 PM
Thanks Saurabh
06-28-2015 10:05 AM
Happy to help :)
