Cisco UCS Platform Emulator™ Control Panel
i am using Cisco UCS Platform Emulator™ Control Panel  3.0 once i try to add new chasis or copy existing chasis getting below error could you provide me solution
Exceed max chassis number(1)
Saurabh Kothari
Hey Moazzam,
thanks for posting your query.
3.0 --> https://communities.cisco.com/docs/DOC-53980
Cisco UCS PE 3.0 only supports the 6324 Fabric Interconnect based domains.  No other Fabric Interconnect (6100 / 6200) will work with this UCSPE.
The release supports having only 1 chassis and 4 rack servers as of now. Hence the user cannot configure more than 1 chassis.
If you would want to use 6100 / 6200 Fabric Interconnects or multiple chassis, you can download Cisco UCS Platform Emulator (2.2(2cPE1)) --> https://communities.cisco.com/docs/DOC-52943
Please read for more information-- https://communities.cisco.com/docs/DOC-37827
Saurabh
Saurabh Kothari
Hey Moazzam,
Saurabh
Thanks Saurabh
Happy to help :)
