Cisco UCS Solution validation / test case
Dear All,
Does anybody have cisco UCS solution test case schenarios and expected results to validate the solution which should cover all expects as mention bellow
(1) cisco chassy componant failure and expected result
(2) cisco blad failure and expected result
(3) vmware failures behaviour which include HA DRS and storage DRS
(4) network swith fail and expected results on chassy blad vmware and storage
(5) netapp storage fail and expected result on vmware chassy blad and storage
Kalpesh
hardhattek
Visitor
Here you should find a fair amount of testing for the ucs environment http://ciscoquicklinks.com/Tip-datacenter-ucs-test-redundancy. As you do this you should warning/alarms in the vcenter console. I think this a good start with the ucs. As for netapp you may start here https://library.netapp.com/ecmdocs/ECMP1196796/html/GUID-31D6327E-48F5-461D-9C5B-9F0BDE2C7783.html. If you configured a HA environment, you should see reduncacy lost without reboots, etc.
