Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco UCS traffic monitoring
Asfandyar70754
Hello everyone.
I am running 50 Servers and 6 Chassis in my environment. I need a mechanism for Network traffic monitoring that includes UCS vNIC traffic monitoring, traffic monitoring between vlans within a chassis  and visibility that on which blade in the chassis is contributing to the traffic on the port.
Any help is appreciated
Kirk J
Your options are seen at https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-manager/GUI-User-Guides/System-Monitoring/4-1/b_UCSM_GUI_System_Monitoring_Guide_4-1/b_UCSM_GUI_System_Monitoring_Guide_4-1_chapter_01101.html
Traffic Monitoring Across Ethernet
An Ethernet traffic monitoring session can monitor any of the following traffic source and destination ports:
Source Ports
                 Destination Ports
  • Uplink Ethernet port
  • Ethernet port channel
  • VLAN
  • Service profile vNIC
  • Service profile vHBA
  • FCoE port
  • Port channels
  • Unified uplink port
  • VSAN
Unconfigured Ethernet Port
Note
All traffic sources must be located within the same switch as the destination port. A port configured as a destination port cannot also be configured as a source port. A member port of a port channel cannot be configured individually as a source. If the port channel is configured as a source, all member ports are source ports.
Kirk...
kbhagat
Check this out -- Might be exactly what you are looking for
Main Landing Page: https://github.com/paregupt/ucs_traffic_monitor
