Configuration Guide for 6248 and 5548 and VNX 5500
Amit Vyas
Need help here to configure the FCoE Uplink + Ethernet Uplink in Port channel
Following is the connectivity details from 6248, 5548 and VNX5500.
I have configured Port Channel in following way on Both Fabric Interconnect
After Configuring above things I am getting following Faults on Servers
For NetApp3240 ENM source pinning failed, I have allowed VLAN ID 21 in Uplink manager then too this Link state is  not showing UP and Same thing go for both FC_vHBA
Kinldy help me to configure the setup
-Amit
17 Replies 17
Thanks a lot Padma for your help till now
Your last comment done the trick here.. I made changes at FI level which you suggested i.e. single port channel interface have 6 interfaces and "vpc" on N5K came up as expected
Also want to know that can we do FCoE vPC between 6248 & N5K ?
Thanks once again
-amit
FCoE over vPC (  FI <--  vPC+FCoE --> N5K )  is not supported.
Is it FCoE end to end or FC between N5K and VNX ?
UCSM 2.1 is required for FCoE uplink from FI.
Sample configuration is available here
https://supportforums.cisco.com/thread/2205748?tstart=30
If it is FCoE towards VNX, configuration would be similar as above. If not, you can refer to following guide for FC interface configuartion.
http://www.cisco.com/en/US/products/ps9670/products_installation_and_configuration_guides_list.html
