Configuring VM-FEX For Testing
thehxman101
Is it possible to configure VM-FEX for testing purposes on one blade in a fully populated chassis? I would think it wouldn't be a problem on the UCS side but will this effect other stuff on the vCenter side?
padramas
You can safely test with single blade / Cisco VIC and It should not affect exsting network connectivity within UCS or vcenter.
VM-FEX will be appear as another DVS within vcenter / datacenter.
Padma
