Dialogic PCI card for c200 M4
CSCO12363220
Hi, a want install Dialogic D/600JCT-2E1W PCI card into c220 M4. I'm looked up this card in spec sheet for c220 but not found it. This card compatible with server's pci slot or not?
Justin Welch
If it is not in the spec sheet it is not supported:
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c220m4-sff-spec-sheet.pdf
With that in mind, you could try to use it in your server and it could potentially work. However, if you ever had an issue with the server and had to open a TAC case, etc the card is the first item that would be pointed at as a problem.
Justin
