encs no vga output
I'm not getting any VGA or console output for the bios on several ENCS5412/K9. Once in a while I do get output but it takes literally over a half hour. I have several of them and they all do the same thing.
Mark Elsen
  - The issue you are describing is a known problem with the ENCS5412/K9. The BIOS on these devices can sometimes take a long time to initialize, and in some cases, it may not initialize at all. There are a few things you can try to fix this problem:
Make sure that the BIOS is up to date. The latest BIOS for the ENCS5412/K9 can be found on the Cisco website.
Try resetting the BIOS to factory defaults. To do this, press and hold the Mode button while you power on the device.
If you are still having problems, you can contact Cisco support for further assistance.
Here are some additional troubleshooting tips that may help:
Make sure that the VGA cable is properly connected to the device and to the monitor.
Try using a different VGA cable.
Try connecting the device to a different monitor.
Try changing the BIOS settings to use a different video output mode.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
