Errors on FC port
kunal.bhadra1
I can see 2 errors on one of the FC port in FI-A this morning as shown below.
792360002179 frames input, 1385887602556848 bytes
0 discards, 0 errors
0 CRC, 0 unknown class
0 too long, 0 too short
554127723180 frames output, 976389804559700 bytes
0 discards, 2 errors
How to check what is these errors and what time this are reported?
Please help.
mojafri
Hi @kunal.bhadra1,
For detailed counters you may run below command in nxos mode:
#show hardware internal fc-mac 1 port 32 statistics (for eg. fc 1/32)
Like any other counters in switching world, it won't tell you when it occurred, unless you have some monitoring system. You should be only concerned if it is increasing.
Please rate if you find it helpful.
MJ
