F1004, Controller .... is inoperable; Reason: CIMC did not detect storage
Walter Dey
Infrastructure is at 2.2.6d.
Customer needed NVIDIA M& GPU, which requires 2.2.7.
B200-M4 at 2.2.6d
We created Host Firmware package 2.2.7 and linked this to the propriate Service Profile.
Capability Catalog was also updated to 2.2.7.
Now, we see an ugly critical error poping up:
F1004, Controller .... is inoperable; Reason: CIMC did not detect storage ! see attachment !
Facts:
- OS is installed on local disk and is booting and working !
- decommission / reack of the blade doesn't clear the error
Defect ID
Symptom
First Bundle Affected
Resolved in Release
CSCuv46749
When using Cisco B200 M4 blade servers with the UCSB-MRAID12G storage controller, the following random, incorrect transient alerts or faults are no longer reported:
  • Critical Fault [F1004] Controller Inoperable, Reason: Device reported corrupt data.
  • Critical Fault [F1004] Controller Inoperable, Reason: Device non-responsive.
2.2(3g)A, 2.2(6d)C, 3.0(2c)B
 3.1(1g)
9 Replies 9
Paul Felts
Hello Walter,
What OS is the blade currently running? If you're running ESXi please provide the output for the following command from the ESXi CLI:
esxcfg-scsidevs -a
-AJ
Hi Paul
No, it's Windows, I think 2008 R2 !
I just remember, that most likely they did not update the drivers (was 2.2.3d before the upgrade).
Walter.
Hello Walter,
We want to make sure that the RAID Controller is running the megaraid_sas driver and not ls_mr3.
-AJ
Thanks Paul
- Am I correct ? you are referring to Windows Raid Controller setting (not the one done by HFP ?) ?
- how can I find out, and how can it be fixed ? is this part of driver iso package ?
Walter.
PS. Despite this error, OS and data on the local disks are available and working ! this error just popped up, after we applied a HFP 2.2.7 and did a Capability catalog update to 2.2.7
Hello Walter,
Please see the following document: http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C240M4/install/C240M4/raid.html#70245
-AJ
This document refers to C-Series ! we have B200-M4 ? does your comment about raid controller apply as well ?
Walter,
The section that is linked is hardware agnostic.
-AJ
Defect ID
Symptom
Resolved in Release
CSCuv46749
 3.1(1g)
Walter Dey
Thanks Cristobal !
Is there a similar defect for C-series server, e.g.
SR 680411058 : F1004 : Equipment Inoperable StorageController 3
Walter.
